B20 rod ratios
Old Jan 13, 2002 | 09:19 PM
FreeMyndz v.FP's Avatar
Default B20 rod ratios
OK, I have been hearing that when some people do a B20VTEC that they change out the CRV crank for a B17 crank...I know it will work but don't you lose torque(the whole reason to go B20) with the shorter stroke???
_______
Old Jan 13, 2002 | 10:19 PM
Suprdave's Avatar
Default Re: B20 rod ratios (FreeMyndz)
1.54:1 Normally.
Noone does the B17a Crank.
The 1.8L with a 1.7x R|S Ratio is nice, but you loose yer torque. I dont know of anyone whos built it like that. You can turn ~9000rpm with the 1.54:1 with a fully built setup (Rods, Girdle, Balancing, Etc...) So the B17a Crank isnt really needed.
Rpm breaks things anyways. Also, there are All-Motor Teams like Ericks Racing that are turning 10-11k rpm with a 1.58:1 Ratio GSr and **** like that...and the B18C5 turns a 8700 Redline with 1.58:1, so its not really a big deal. If you gonna put a **** ton of Boost into it all the time, then youll achieve greater reliability with the B17a Crank. Its not that big of Deal. Just a 1.8L B16a
Suprdave
Old Jan 14, 2002 | 04:05 AM
mps9506's Avatar
Default Re: B20 rod ratios (Suprdave)
In addition to that you will have a hell of a time finding one...
supra-n-civic
Aug 10, 2009 07:44 PM
DAYUIZ
Jan 14, 2003 12:21 AM
FreeMyndz v.FP
Jan 15, 2002 05:26 PM
XSBoost
Jun 12, 2001 10:46 AM
