Golden Eagle sleeved block, mains stamped STAY
Old Jan 27, 2005 | 06:26 AM
86si's Avatar
Default Golden Eagle sleeved block, mains stamped STAY
I bought a used GE block and instead of the normal 5 letter code for the main bearnings it is stamped with the word STAY? WTF? Any know what this means?
Old Jan 27, 2005 | 07:08 AM
Ekasey's Avatar
Default Re: Golden Eagle sleeved block, mains stamped STAY (86si)
You can always call golden eagle and ask them!
Old Jan 27, 2005 | 07:24 AM
86si's Avatar
Default Re: Golden Eagle sleeved block, mains stamped STAY (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">You can always call golden eagle and ask them!</TD></TR></TABLE>
I did and they have never seen this
Old Jan 27, 2005 | 08:07 AM
b18bturbo's Avatar
just measure your clearances manually and get the correct bearings it going ot be little difficult but thats what you have to do if the code is not there as a starting point. Do you know if the block has been line honed as well
Old Jan 27, 2005 | 08:49 AM
86si's Avatar
Default Re: Golden Eagle sleeved block, mains stamped STAY (b18bturbo)
i am not sure if it was line bored. but i guess i will get some plastigauge and get started.
Old Jan 27, 2005 | 09:03 AM
86si's Avatar
any one use clevite bearings?
Old Jan 27, 2005 | 09:18 AM
vtecmissle's Avatar
precision engine used coated clevite bearings in a 1000 hp b series build. Worked fine
Old Jan 27, 2005 | 05:30 PM
PrettyLude's Avatar
use oem bearings
Old Jan 27, 2005 | 05:31 PM
TeStUdO's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">use oem bearings</TD></TR></TABLE>
ACL's are decent as well
Old Jan 27, 2005 | 05:37 PM
GDM Z28's Avatar
Default Re: (TeStUdO)
im running ACL's and i love em
Bond
May 6, 2009 09:57 PM
92VXeg
Sep 21, 2008 03:04 PM
95lscivic
Aug 10, 2006 04:54 AM
VWkila
Feb 22, 2003 10:47 PM
