Alarm experts – DIY basic Viper - 94 civic ex
Old Jan 27, 2005 | 12:45 AM
The Alchemist...
Guest
Posts: n/a
Default Alarm experts – DIY basic Viper - 94 civic ex
Basically my goal is to stop thieves and keyless entry. I used to work in a car audio store and I know that you can do a lot with a basic Viper – more then I need. My idea is to install it myself and just take my time doing it. This will be the first alarm I install on my own but I have helped before and I know if you diy it you can take the extra little steps like blacking off the wires with tape and hiding the valet button well. I noticed that when you take a car into get an alarm most of the time the installer does a very typical / average install that most thieves expect. Now my problem is I would hate to get ½ way though installing the alarm and get stuck. I do have the option of trying to get a hold of the installers I used to work with but I doubt any of them are around now. I am not sure exactly what my question really is but what do you all think? Has anyone here installed an alarm themselves with little or no experience? I have a 94 civic ex by the way with power everything.
Old Jan 27, 2005 | 07:17 AM
kac3r's Avatar
Default Re: Alarm experts – DIY basic Viper - 94 civic ex (w-a-o)
you just gotta know where the wires go. ive installed 3 alarms with remote start 2 way paging blah blah. installed them into my 94 teg, 92 hatch, and 2000 montero. id take my time tho. for my teg i took the extra time and extended the wiring from my brain so i could relocate it took me a good couple hours to extend everything. but id say its pretty straight foward just match up the wires.
Old Jan 27, 2005 | 07:48 AM
The Alchemist...
Guest
Posts: n/a
Default Re: Alarm experts – DIY basic Viper - 94 civic ex (kac3r)
Yeah I think if I can get a print out I could do it if I took my time. The problem is I don’t have that program anyone. I think its called “tech soft” and authorized dei dealers have it. You put the year make model of the car and it gives you a print out of where all the needed wires are. If anyone has that please let me know.
Old Jan 27, 2005 | 08:28 AM
kac3r's Avatar
this should be it http://www.directwholesale.net...LLDOG
or http://www.bulldogsecurity.com/
Old Jan 27, 2005 | 08:36 AM
The Alchemist...
Guest
Posts: n/a
Honda
Civic
1992-1994
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/WHITE
IGNITION SWITCH HARNESS
Ignition #1:
BLACK/YELLOW
Ignition #2:
YELLOW
Ignition #3:
N/A
Accessory:
WHITE/BLACK
Brake Light:
GREEN/WHITE
(+) SWITCH ON BRAKE PEDAL BRACKET
Tach Signal:
BLUE
AT DISTRIBUTOR OR TACH TEST CONN. *
Parking Lights:
RED/BLACK (+) AT GREEN
CONNECTOR UNDER DASH OR IN FUSEBOX
Headlights:
RED/WHITE (LOW)
RED/BLUE (HI) AT HEADLIGHT SWITCH (+)
OEM Alarm Disarm:
N/A
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Tach Test Connector (White 2 Pin) Found In Driver Rear Of Engine Compartment. BLUE Tach Wire Also Found In Gray 14 Pin Connector On Top Of Fuse Block At Pin #3.
Honda
Civic
1992-1994
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE
Starter Kill:
BLACK/WHITE
Ignition +12 Volts:
BLACK/YELLOW
Dome Lights/Superv:
GREEN/RED
(-) DRIVER KICK PANEL
OEM Horn:
BLUE/RED OR GRAY
(-) STEERING COLUMN HARNESS
Power Lock:
GREEN/WHITE
SWITCH OR DOOR LOCK CONTROL
Power Unlock:
GREEN/RED
UNIT IN DRIVER DOOR **
Trunk Release:
N/A
Alarm Input Wire:
GREEN/RED
Notes:
** See Note #201 - Negative Pulse Door Lock Diagram.
I <3 h-t
Old Jan 27, 2005 | 08:38 AM
The Alchemist...
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kac3r &raquo;</TD></TR><TR><TD CLASS="quote">this should be it http://www.directwholesale.net...LLDOG
or http://www.bulldogsecurity.com/</TD></TR></TABLE>
Thanks man
https://honda-tech.com/zerothread?id=584724 &lt;--- makes it look easy
Modified by w-a-o at 10:00 AM 1/27/2005
Old Jan 27, 2005 | 02:44 PM
Auex's Avatar
Here is the Tech soft equivalent.
Old Jun 18, 2006 | 06:48 PM
OshkyCiv23's Avatar
Default Re: Alarm experts – DIY basic Viper - 94 civic ex (Auex)
good thread....
Old Jul 31, 2006 | 11:50 PM
Fallen86's Avatar
Default Re: Alarm experts – DIY basic Viper - 94 civic ex (OshkyCiv23)
wooo asked my question for me.
Old Aug 1, 2006 | 01:43 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Alarm experts – DIY basic Viper - 94 civic ex (Fallen86)
how the hell did you get your post count to zero and rating, lol wait a min, look at the date of this. Back from the grave.
Old Aug 1, 2006 | 10:30 AM
Fallen86's Avatar
Default Re: Alarm experts – DIY basic Viper - 94 civic ex (wrx-killer-Sti eater)
lol i just needed to bookmark it
koldkustoms
Audio / Security / Video
Mar 13, 2007 05:59 AM
ProjectDarkBlack
Feb 10, 2006 04:02 PM
migizzel
Jan 27, 2006 03:37 PM
epraion62
28
Aug 25, 2005 09:58 AM
DEVINEER
Jul 19, 2005 08:51 AM
