H22 Swap question
Old Jan 13, 2002 | 08:35 PM
m0t0rhead's Avatar
Default H22 Swap question
What are the usual things that go wrong with an H22A swap ?
I have a 97 EX 5-spd. What should I expect guys ??
Scared to make the plunge ... Found a motor as cheap as 2300$.
JDM H22A w/ under 30k.
Old Jan 14, 2002 | 01:12 PM
Boughetto's Avatar
New User
Default Re: H22 Swap question (Escobar)
post pics of your car, it sounds nice, as far h22, do a search, I have seen so many topics on it, or try the hybrid forum
Old Jan 15, 2002 | 07:23 AM
Nick M's Avatar
Default Re: H22 Swap question (blue95accord)
EGR valve is a typical pain in the ***. Problems that can pop up are a broken TPS (throttle position sensor, occurs when installing the engine if u arent careful) the only other real problem that occur are if you attempt to do this yourself and dont know anything about it ex: use the lude drivers side motor mount and shave alittle bit off to make it fit perfectly, etc etc, there are alot of little things to know before u attempt to do it. A good place to look is the hybrid forum on hondasociety.com for accords, lots of info.
Dom_702
Nov 27, 2013 09:12 PM
justus3
Feb 10, 2005 08:05 AM
civic01mtx
Jul 8, 2004 12:49 PM
makaveli284
Sep 20, 2002 08:50 AM
1997Accord
May 18, 2002 10:36 AM
