problems after putting on new head gasket
Old Jan 26, 2005 | 03:58 PM
zombie247's Avatar
Default problems after putting on new head gasket
I have a 93 civic four door (as says in sig) d15b7, i just put a new headgasket..timingbelt..spark plugs...filters. and my ac nor heat kicks on anymore. I'm sure i probly didn't plug something back up. Has anyone else had this problem? What do you think i didn't put on? Also my timing is 16 degrees off but the crank #1 is TDC and the cam gear is up and all is straight. The distributor is also all the way to the left. i can't turn it anymore. Also its a remanufactured Dizzy. Is there a possibillity (sp) that someone that worked on the car before put the wrong one on? The car runs, but i get shitty gas milage and not any power until like 4000 rpm.
CLIFF NOTES: put new headgasket on
heater and a/c don't come on anymore
off 16 degrees in timing... could there be a possibiltywrong distributor
If you didn't understand what i'm saying, i'm sorry...
Old Jan 26, 2005 | 04:01 PM
JDMisGOOD's Avatar
Default Re: problems after putting on new head gasket (zombie247)
well to start with fix the damn timing...as for the ac and heat not working...sounds electrical...check fuses and connections!
Old Jan 26, 2005 | 04:05 PM
zombie247's Avatar
Default Re: problems after putting on new head gasket (JDMisGOOD)
my auto teacher and i have been trying to fix the timing...its not off on the belt. and i can't turn the dist anymore...i think this car has been fucked before i bought it
Old Jan 26, 2005 | 04:07 PM
jlacoy82's Avatar
71.192.16.183
You do realize your timing is supposed to be at 16 degrees right? You dont want your timing set ***** on with the TDC mark on the crank pulley.
Old Jan 26, 2005 | 04:40 PM
Archidictus's Avatar
Unceasing Measure
Default Re: problems after putting on new head gasket (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">You do realize your timing is supposed to be at 16 degrees right?</TD></TR></TABLE>
I don't think he does.
Put the dizzy back at its normal position and check the firewall for undone connections and possibly a small, looped wire that goes onto the heater-actuator valve lever.
Old Jan 26, 2005 | 06:22 PM
zombie247's Avatar
Default Re: problems after putting on new head gasket (Archidictus)
sorry i'm tarded.. i need to like turn it 7 degrees or some **** and i can't advance it anymore like i need to. its bottomed out. i was mistaking it for 16 because thats what the all-data said...16 degrees at 570 or some ****... i dunno..i'll get it going right
Old Jan 27, 2005 | 12:37 PM
zombie247's Avatar
diffrent distributor and a connection was loose under the dash, car runs fine..thanks
crvglenn
Honda CR-V & Element
Sep 11, 2017 03:42 PM
fsl
Jul 12, 2012 05:56 AM
stackz
Feb 17, 2012 10:50 AM
krypt1c
Apr 1, 2010 12:39 PM
civicracer1993
Nov 8, 2002 09:38 PM
