Problem Removing Cluster
well i can take the screw off on the right, but the left one just twists but doesnt come out. what should i do? will taking it off with one screw still on mess things up badly?
The plastic threads are probably stripped out, which in that case, no, as long as you dont pull on the cluster face too hard, it shouldnt harm anything. Just put pressure pulling down on that area as close to the screw as possible so most of the force is directly on the screw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_CARY »</TD></TR><TR><TD CLASS="quote">screws on what?
im confused
the 2 screws are on the dash, but u need to take them off the get to the cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">The plastic threads are probably stripped out, which in that case, no, as long as you dont pull on the cluster face too hard, it shouldnt harm anything. Just put pressure pulling down on that area as close to the screw as possible so most of the force is directly on the screw.</TD></TR></TABLE>
so if i pull it out i will only be able to use 1 screw to secure it again?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorHB »</TD></TR><TR><TD CLASS="quote">Is it loose up top on both sides where the screws are?
one screw comes off on the right, the other doesnt not come off
im confused
</TD></TR></TABLE>the 2 screws are on the dash, but u need to take them off the get to the cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Put downward pressure on the left side by pulling down on the cluster face while slowly backing the screw up, you may be able to back the screw out that way.</TD></TR></TABLE>
good idea..im gona try that
JDMTRSPORTS
12
Oct 28, 2005 01:47 PM
