my ecu is going crazy....
i have a 1990 crx hf stock motor with si tranny, my ecu has been throwing crazy codes when it bogs down it will throw a different one everytime. it throw an automatic tranny code, n.1 cylinder position code which is crank angle senser i checked the dizzy it was fine. it also throw an intake air temp sensor code my car doesnt have one, hopefully someone can help me. oh yeah it has a lope at idle. thanks for the help
Is your timing all set properly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf_gsr_blades »</TD></TR><TR><TD CLASS="quote"> it also throw an intake air temp sensor code my car doesnt have one</TD></TR></TABLE>
I'd get one...
Also, what ECU are you using?
I'd get one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">Also, what ECU are you using?</TD></TR></TABLE>
ditto.....
ditto.....
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">then you need to know how to read codes if its the factory ecu...
1 long blink = 10, 1 short blink = 1</TD></TR></TABLE>
no thats only for OBD1 on the CEL. count the blinks and thats ur code. 5 blinks = code 5, 13 blinks = code 13 ETC...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">no thats only for OBD1 on the CEL. count the blinks and thats ur code. 5 blinks = code 5, 13 blinks = code 13 ETC...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang »</TD></TR><TR><TD CLASS="quote">it says that but all the codes that ive checked for ef's have been all fast blinks, regardless 1 blink or 20 blinks..
yup ditto
</TD></TR></TABLE>yup ditto
Bad ECU maybe? I know you said its throwing codes, but try a known good ecu. Usually when an ECU is screwed the red LED light stays on permanently, you did not mention that, but I'm just throwing out ideas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxsib16 »</TD></TR><TR><TD CLASS="quote">Obd0-B16-PW0 and I get long blinks....</TD></TR></TABLE>
thats true but we are talking about a usdm ecu
Ok, i Thought i was going CRAZY! I have been messing with this new car i just bought and it was blinking like 20 short blinks in a row, but my B16 car used to throw long blinks. So i thought the ECU was fudged.
Jason.
Jason.
ok, i guess i might be semi-wrong then...i never had to deal with codes that were 17 short blinks...only time i really had to deal with codes where when the car had b-series and it was the long and the short blinks...sorry...
Bseriesy0
Nov 29, 2003 11:46 AM
