Sleeved b20 or Sleeved and bored to 84mm b18b?
Old Jan 26, 2005 | 12:47 AM
hazard_one's Avatar
Default Sleeved b20 or Sleeved and bored to 84mm b18b?
is it basically the same thing? or is there a difference. this is assuming i have same compression pistons as well. which would cost more? and if i plan to go vtec later on, i hear an ls/vtec is less reliable than a b20/vtec would it be the same case with the bored out ls?
Modified by Trunks714 at 10:34 AM 1/26/2005
Old Jan 26, 2005 | 06:29 AM
NJIN BUILDR's Avatar
Default Re: Sleeved b20 or Sleeved and bored to 84mm b18b? (Trunks714)
You end up with the same end result.The b18b will probably be cheaper to buy than the b20.The ls/vtec isn't any more or less reliable than the b20/vtec.
Glenn
Old Jan 26, 2005 | 08:07 PM
hazard_one's Avatar
Default Re: Sleeved b20 or Sleeved and bored to 84mm b18b? (NJIN BUILDR)
any other opinions?
Old Jan 30, 2005 | 04:31 AM
StorminMatt's Avatar
They are, for the most part, the same thing. After all, the B20 is basically just a 'big LS'. There are, however, a couple of things to keep in mind. First of all, an LS is going to cost ALOT less than a B20. So if you are going to sleeve anyway, just go with the LS. The B20 is really only a better way to go if you just plan to run the motor basically stock, in which case a B20 will cost ALOT less than a sleeved LS. Secondly, the sleeved LS has the advantage of having a B18A/B18B block stamp. This is important if you live in a places like California, where you must deal with a visual smog inspection. And finally, the PCV system is somewhat different on the B20 block, necessitating the use of a B20/newer B18B valve cover. The LS has a PCV system more like a VTEC motor, making this easier to set up if you go VTEC.
Old Jan 30, 2005 | 09:25 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
^^good info
4thgenx42
Sep 25, 2006 04:15 AM
latinf86
Jun 25, 2006 11:45 PM
civic5483
31
Mar 7, 2004 11:13 AM
TwistedHatch
Aug 17, 2003 06:54 PM
es four
Oct 29, 2002 09:50 AM
