Passing smog in Cali with a engine swap
Old Jan 25, 2005 | 09:42 PM
blindpug's Avatar
Default Passing smog in Cali with a engine swap
Hey, I have read just about everything about Cali engine swaps but still have some questions. I have a 94 Civic LX and it had the SOHC Non Vtec 1.5L 104HP engine. Well I changed out to a Vtec d15b I believe, the 130hp Japanese special edition from 93-95. I also have a cheesy cheap short ram intake, Holley Airmass headers and catback. I know the cat and Headers are 50 states legal and looked at the Cali website and they were legal. What I am unsure of still though is the engine itself. The engine is from the same year civic models as mine. Problem is when I got the engine put on he wasnt sure what year exactly it was, just that it was a import japan engine with about 60k miles on it. It actually came in from CAli as I am in AZ. I asked them to install everything to cali safe as possible but they also dont really know much about Cali laws here in AZ. So basically I am asking if anyone has any info or another resource telling me if this engine will be ok with minor Cali adjustments or if its going to fail with major probs. If anyone has any information, or a site that lists this engine as being legal etc. Thanx a lot
Old Jan 25, 2005 | 09:45 PM
SmogTech01's Avatar
Default Re: Passing smog in Cali with a engine swap (blindpug)
im a smog tech i work in north hollywood southern cali ur car wont pass because of the swap unless u get it Refree checked and thats a bitch to pass theyre ******** if u live around i can take care of it for u
Old Jan 25, 2005 | 10:01 PM
boosting_crx's Avatar
Default Re: Passing smog in Cali with a engine swap (SmogTech01)
im trying to pass my 90si crx with a b16a swap thats turboed can you help me too email me at anthony_215@hotmail.com
Old Jan 25, 2005 | 10:12 PM
Steemo's Avatar
Default Re: Passing smog in Cali with a engine swap (boosting_crx)
honestly if you have a 94 civic and its still an sohc motor i really doubt they are going to say anything to you its nothing all that drastic and the casting on the block still says d15 to start with and a majority of smog stations arent going to pick up on that especialy since many cars of that year came with a vtec motor. I think you should be fine.
Old Jan 25, 2005 | 10:35 PM
Rywire's Avatar
Default Re: Passing smog in Cali with a engine swap (Steemo)
http://www.norcalcrx.org/libra...shtml
Old Jan 25, 2005 | 10:41 PM
CR_VtecCRX89's Avatar
Default Re: Passing smog in Cali with a engine swap (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">http://www.norcalcrx.org/libra...shtml</TD></TR></TABLE>
good looking out
Old Jan 25, 2005 | 11:22 PM
Rywire's Avatar
Default Re: Passing smog in Cali with a engine swap (CR_VtecCRX89)
No prob
Ryan
Old Jan 26, 2005 | 04:15 PM
blindpug's Avatar
Is there a way to check the engine for what year it is? Or does a Tech just have a guide saying this engine was made in so and so year and that these cars will have it? I am trying to find out how if it is possible the tech would know if my engine is a 93 or 94 or what.
Old Jan 26, 2005 | 04:25 PM
michael O's Avatar
Default Re: (blindpug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindpug &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way to check the engine for what year it is? Or does a Tech just have a guide saying this engine was made in so and so year and that these cars will have it? I am trying to find out how if it is possible the tech would know if my engine is a 93 or 94 or what. </TD></TR></TABLE>
There is no way they could know what year the engine is. If I were you though I'd ask the companies for the headers and intake if they could send you the carb sticker for the parts. That way I'm almost positive that you would pass smog with those at any normal smog station.
Old Jan 27, 2005 | 12:29 PM
BeavisB16's Avatar
Default Re: (michaelOlson)
Why are you worried abut cali laws when your in arizona?
Old Jan 27, 2005 | 12:34 PM
PHOBIA's Avatar
what do you mean theres no way for them to tell the year of the engine,its stamped right on the head.
Old Jan 27, 2005 | 12:46 PM
bossman032's Avatar
Default Re: (PHOBIA)
if its a stock motor I mean usa motor single head motor it shouldn't have a problem passing. as long as the cat o2 and wiring and no check engine lights
b series is different story
Old Jan 27, 2005 | 11:21 PM
blindpug's Avatar
I am planning on moving to California in March. Where can I find the engine stamp? From what I was told by the guy who put it in, there is no stamp on my engine to indicate the year. Altho I read that if it says something like 9/2 or 90 or something like that on it that it indicates the year. Mine has 4 at different degrees saying 9/2 9/0 9/0 9/0. If thats of any help. If thats not it, where would the "stamp" be located cause I cant find anything on the head that would indicate anything and those numbers I listed were right above where the headers connect.
Old Jan 27, 2005 | 11:29 PM
blindpug's Avatar
also, if I go in for a smog check and they do the visual inspection. Is the inspector going to look and assume anything? Since mine looks like a EX engine in the first place is he going to go about it normal, or do all inspections check vins etc? I figure the engine is and made for this car and year model etc looks just like the basic EX engine model that they wont think twice. But if they do a vis check and then check everything with a fine tooth comb its gonna get complicated. Also, my car is a LX anyways, so they prolly are gonna get leary at the fact that there is an EX engine in it.......
Old Jan 28, 2005 | 12:13 AM
blindpug's Avatar
PS The engine code of my Engine is actually a D15B engine.
Old Jan 28, 2005 | 12:56 AM
fourthgenhatchB17's Avatar
If u swapped a SOHC for another SOHC, dont worry. 95% of the smog places wont care. Hell, my 89 DX had a sohc ZC with the MPFI manifold and i passed fine, visual and everything. I even witnessed a friend of mine pass visual when he had an ebay intake and header (no CARB numbers). U have nothing to worry about, but just for the sake of it, throw on the stock air box and pipe.
edit: im talkin about Cali smog, not AZ. WTH u wanna know about cali stuff when u dont even live here?
Old Jan 28, 2005 | 04:38 PM
BeavisB16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">If u swapped a SOHC for another SOHC, dont worry. 95% of the smog places wont care. Hell, my 89 DX had a sohc ZC with the MPFI manifold and i passed fine, visual and everything. I even witnessed a friend of mine pass visual when he had an ebay intake and header (no CARB numbers). U have nothing to worry about, but just for the sake of it, throw on the stock air box and pipe.
edit: im talkin about Cali smog, not AZ. WTH u wanna know about cali stuff when u dont even live here?</TD></TR></TABLE>
Yeah, if your still SOHC you probably wont have problems.
EDIT:Might even find a shop to wld on your old engine code over the new one...if your that concerned
Modified by BeavisB16 at 11:01 AM 1/30/2005
laumen1991
Northern California
May 8, 2013 12:29 AM
THC07
Oct 7, 2005 07:24 PM
kinvid22
Mar 31, 2004 03:05 PM
LB CRX
Jul 13, 2003 03:14 PM
