Welding combustion chambers??
Old Jan 25, 2005 | 05:41 PM
angry_LS's Avatar
Default Welding combustion chambers??
Do you know what the process is and what it does?
TIA
Old Jan 25, 2005 | 07:33 PM
Master23's Avatar
Default Re: Welding combustion chambers?? (angry_LS)
I Think your talking about welding the open deck of Honda's blocks to make the cylinder walls stronger. This process should be done by experienced technicians or mechanics since it involves welding in a block gaurd and then shaving off the exess material on top to make it flush with the block.
Old Jan 25, 2005 | 08:06 PM
angry_LS's Avatar
Default Re: Welding combustion chambers?? (Master23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master23 &raquo;</TD></TR><TR><TD CLASS="quote">I Think your talking about welding the open deck of Honda's blocks to make the cylinder walls stronger. This process should be done by experienced technicians or mechanics since it involves welding in a block gaurd and then shaving off the exess material on top to make it flush with the block.</TD></TR></TABLE>
No, I'm talking about welding combustion chambers, as in cylinder heads. I've heard it's kind of like polishing them, but I'm not sure. Anybody can help me out here??
TIA
Old Jan 25, 2005 | 08:33 PM
cheesebug's Avatar
Welding a combustion chamber is done in order to decrease its volume, thus raising your compression ratio. You run into problems such as severe warpage, unequal chamber volumes, and seats and guides falling out due to the expansion of the aluminum. You're better off just going to a higher compression ratio piston unless you have lots of time, money, or skill.
Old Jan 25, 2005 | 09:14 PM
tegmech's Avatar
wouldn't that create hot spots in the chamber? leading the engine to premature detonation?
Old Jan 25, 2005 | 09:21 PM
cheesebug's Avatar
Default Re: (tegmech)
It would if you were not going to reshape the chamber. Like I said if you have lots of time, money, or skill it's worth doing. If not, leave well enough alone.
Old Jan 26, 2005 | 07:24 PM
FLOWZILLA's Avatar
Default Re: (cheesebug)
WELDING THE COMBUSTION CHAMBER IS A FAIRLY SIMPLE PROCESS ,WHEN DONE CORRECTLY THERE ARE NO SIDE AFFECTS IVE BEEN WORKING WITH WELDED CHAMBERS FOR YEARS AND HAVE NOT HAD ANY OF THE ISSUES THAT WERE STATED ABOVE .. NOT ONLY DOES IT RAISE COMPRESSION BUT IT ALSO GIVES YOU QUENCH PADS THAT HELP AID AGAINST DETONATION BY TRANSFERRING AIR FUEL MIXTURES TOWARDS THE SPARK PLUG DURING THE COMPRESSION STROKE. BY WELDING A CHAMBER YOU ARE ADDING MORE MATERIAL THUS LOWERING VOLUME OF CHAMBER . BY DOING THAT YOU ARE GIVING THE CHANCE TO UNSHROUD THE VALVES MORE,ADDING THE ABBILITY TO FLOW MORE .. AND IN MOST CASES CAN BE MUCH CHEAPER THAN BUYING FORGED PISTONS... EXAMPLE: FORGE PISTONS $480 PLUS MACHINE SHOP COST AND MISC. PARTS YOU ARE LOOKING AT ABOUT $880 AND THATS IF YOU ARE GOING TO ASSEMBLE THE ENGINE IF NOT ADD ANOTHER 300-500 DEPENDING ON BUILDER. WELDING CHAMBERAND RESHAPING IT RESURFACING IT $350
Old Jan 26, 2005 | 08:43 PM
mmuller's Avatar
Mad Scientist
Default Re: (FLOWZILLA)
yep, most reputable head porters will weld the combustion chambers.
its done, as flowzilla sayd to build bigger/better quench pads and also improve the chamber design for example to a cleaver loaf design.
Old Jan 27, 2005 | 08:32 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLOWZILLA &raquo;</TD></TR><TR><TD CLASS="quote">WELDING THE COMBUSTION CHAMBER IS ... blahbidy blah blah ... WELDING CHAMBERAND RESHAPING IT RESURFACING IT $350</TD></TR></TABLE>
Fix your damn CAPS LOCK key and stop yelling at us you idiot!
lukehowell88
Oct 1, 2007 12:20 PM
b16nonoy
May 15, 2006 05:13 PM
JDM2ndGen
Mar 7, 2004 04:05 PM
baphomet
Dec 8, 2003 02:00 PM
b18cTurbo
May 14, 2003 04:46 PM
