Viper 791 xv shock sensor question.
Old Jan 25, 2005 | 05:38 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Viper 791 xv shock sensor question.
I have this DEI alarm 791 xv to be exact and I had it installed at this one shop. I've noticed that it doesn't set off much and is not sensitive enough. I havent checked where they installed the shock sensor and where would be the best place to mount it? I just hope they didnt put it underneath the steering column where it picks up less vibration. I;ve hear other people with the same alarm which sets off when a bird ***** on their car but mine doesn't. How exactly is sensitivity adjusted on 791 xv's or is it just the location of the sensor that matters? I cant find the instruction manual so I need help! TIA!
Old Jan 25, 2005 | 06:58 PM
kac3r's Avatar
Default Re: Viper 791 xv shock sensor question. (BrokeAssPinoy)
usually the shock sensor will have a adjusting feature to adjust the sensitivity. most likely like other places like best buys curcuit city....etc. they would usually install it under the steering colunm....just take a look for yourself
Old Jan 25, 2005 | 07:20 PM
Default Re: Viper 791 xv shock sensor question. (kac3r)
kool, after I searched, ive read its best to zip tie the DEI shock sensor to the ignition harness? any comment to this? TIA!
Old Jan 25, 2005 | 07:39 PM
kac3r's Avatar
ive always installed the shock sensor to the steering colunm and had no problems at all. as long as its installed in a secure place where it can sense the impact of someone trying to get into your car should be fine
Old Jan 25, 2005 | 08:05 PM
I've read in my manual not to install it underneath the steering column and ive read a lot of ppl tying it to the ignition harness
Old Jan 25, 2005 | 10:02 PM
ImprtTunr's Avatar
DEI alarm's shock sensors are to be zip tied to the harness. Its the clear plastic box. On one of the sides you will see a small orange piece of plastic inside the clear box with a phillips head on it. That is where you adjust for sensitivity. I want to say clockwise is more sesitive and counter-clockwise is less but I could be wrong. Just fool with it.
Old Jan 25, 2005 | 10:18 PM
EGPrelude's Avatar
Default Re: Viper 791 xv shock sensor question. (ImprtTunr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImprtTunr &raquo;</TD></TR><TR><TD CLASS="quote"> I want to say clockwise is more sesitive and counter-clockwise is less but I could be wrong. </TD></TR></TABLE>
correct
Old Jan 26, 2005 | 09:30 AM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
theyyy r'e gr4te
JENNY_EG6
Audio / Security / Video
Dec 21, 2011 09:02 PM
EM2-17
Honda Civic (2001 - 2005)
Sep 24, 2007 06:25 PM
phayzeone
13
Nov 12, 2004 01:03 AM
rody084
Dec 31, 2003 11:49 AM
Nameless RB26
Sep 16, 2003 11:36 AM
