need help car idles crazy!!!!!!
Old Jan 13, 2002 | 03:30 PM
garagespecial
Guest
Posts: n/a
Default need help car idles crazy!!!!!!
it jumps up and down, from 1000 rpm to 1050
does anyone know what might be the problem
b16a i/h/e
i did have oil all in the spark plug cuz my *** forgot to put the rubber stoppers around the valve cover.......i cleaned the oil out....changed the wires, cap/rotor, butdidnt change the spark plugs......was scared oil might creep in if not already...but car still runs fine vtec doesnt hit at times also...thats my weekend...can anyone help?
tia
Old Jan 13, 2002 | 03:41 PM
976's Avatar
976
New User
Default Re: need help car idles crazy!!!!!! (garagespecial)
Check throttle body
IAC valve
Fast idle valve
Water in valve cover, leave wires off for a night
Change plugs - don't use anything other than NGK - please - I really don't want to explain
Good luck...
Old Jan 13, 2002 | 04:53 PM
garagespecial
Guest
Posts: n/a
Default Re: need help car idles crazy!!!!!! (B21A)
thanks....ill see what happens wheni get new spark plugs
Old Jan 13, 2002 | 11:49 PM
onefastcx's Avatar
MAKE SURE THAT ALL THE VACUM LINES ARE CONNECTED
Old Jan 16, 2002 | 06:10 AM
deepnite's Avatar
50 rpm doesnt seem like much a difference..it usaully idels a bit differntly after a intake install takes place..i dont think the idle thing should be affecting the vtec..check the vtec controller...also try a tank of higher octane gas..it might be running a little lean
Old Jan 16, 2002 | 06:32 AM
dirtySOHC's's Avatar
vacuum lines.....
Old Jan 16, 2002 | 07:42 AM
garagespecial
Guest
Posts: n/a
Default Re: need help car idles crazy!!!!!! (SO[vtec]HC)
can you buy hoses for my ride from peb boys or any auto parts store? or should i go straight to honda? i am missing a hose on top of my tb so i dunno where that goes....
Old Jan 16, 2002 | 07:51 AM
deepnite's Avatar
is that the connector to the valve cover vent?..if so..get a hose and connect one to the other
boost4life1
May 15, 2012 08:52 PM
nkmndz
Feb 25, 2012 05:12 AM
nkmndz
17
Jan 5, 2012 07:43 PM
Egreyes
Oct 6, 2010 10:22 AM
D16Z6racing
Jun 15, 2005 06:50 PM
