SOHC Help!!!!
Old Jan 25, 2005 | 02:16 PM
maka's Avatar
Default SOHC Help!!!!
i swapped my d16y8 with a z6 and now i have a check engine light because of the knock sensor. apparently the z6 does not have one so its setting off the check engine light, is there a mod that i will be able to do to make the check engine light go out.
Old Jan 25, 2005 | 02:42 PM
HatchEh2's Avatar
Default Re: SOHC Help!!!! (maka)
are you still using the same ECU from the Y8? that might be your problem, you need a P28 to run the d16z6....or your car could be a dif OBD than the Z6...i could be wrong
Old Jan 25, 2005 | 04:36 PM
sleeping GIANT's Avatar
Default Re: SOHC Help!!!! (HatchEh2)
yes he has an obd-2 car with an obd-1 motor!
Old Jan 25, 2005 | 05:14 PM
jlacoy82's Avatar
71.192.16.183
Default Re: SOHC Help!!!! (sleeping GIANT)
I thought my 98 d16y8 was obd2?
Or did they change obd's between generations?
Rockstar4556
Apr 22, 2013 10:26 AM
SH
Sep 28, 2007 05:50 PM
r1ch1e
Feb 11, 2006 04:13 AM
speedehatch
20
May 15, 2004 10:54 AM
dabigfunkymunky
Aug 11, 2001 11:02 AM
