radiator question
Old Jan 25, 2005 | 01:51 PM
elrandeeto's Avatar
Default radiator question
i recently fixed my fitv , and after i had it back on i noticed i was leaking antifreeze towards the back of the motor . well i found out it was one of the two lines coming from the fitv had cracked , so i replaced both of them solved the problem .
Since then ive drove it 3 times , and today went out to check on my rex and opened the hood and noticed coolant pooled at the bottom of the radiator and along the top . I then took the rad. cap off and noticed it was low . The coolant on the top might have been from me filling it but def. not the coolant at the bottom .Ichecked the fitv lines there not leaking .
So i think my radiator is bad didnt look around alot bc its really cold out but i was thinking about getting some of that stuff bars leak that stops radiator leaks . I also priced some new raditors not to bad in price .
Now for what im not sure about. I have a 1990 crx si with a b18a1 would i buy and would it fit : an integra radiator or the si one ? .I priced some after market ones like fluidyne but just to expensive for me right now . thanks for the info
Old Jan 25, 2005 | 02:06 PM
4drEF's Avatar
Keyboard Humorist
Default Re: radiator question (elrandeeto)
If you didn't have any overheating problems with the radiator you had in there then just get a replacement. No need for a fluidyne unless you really have cooling problems or if you are a bling-bling ***** and just like to spend money.
Old Jan 25, 2005 | 02:11 PM
elrandeeto's Avatar
Default Re: radiator question (4drEF)
thanks for the info , i dont have an overheating problem so im gonna get a replacement , but i dont know if its the si radiator o an integra . does the teg radiator even fit in a crx? i didnt do the swap im not sure whats in it
Modified by elrandeeto at 3:30 PM 1/25/2005
Old Jan 25, 2005 | 02:33 PM
elrandeeto's Avatar
bump
Old Jan 25, 2005 | 03:29 PM
4drEF's Avatar
Keyboard Humorist
Search function is your friend!
https://honda-tech.com/zerothread?id=162107
Old Jan 25, 2005 | 03:49 PM
elrandeeto's Avatar
thanks for the link i do search alot , but i didnt think i would find this in search is why i asked first . i was wrong thanks
Old Jan 25, 2005 | 04:04 PM
4drEF's Avatar
Keyboard Humorist
NP - I actually hate the search here.
It normally brings up all kinds of garbage that has nothing to do with what I want to know about.
mouab18c1
Apr 27, 2009 08:21 PM
TsujenDB1
Jul 10, 2007 01:11 PM
Dat_One_Si
Jul 30, 2006 05:28 PM
c1_sleeper
Jul 20, 2006 07:57 AM
jkn1515
Jul 2, 2003 03:33 PM
