1st gear problem
Old Jan 25, 2005 | 12:39 AM
rIceNOodles's Avatar
Default 1st gear problem
I have a little problem with my first gear. when at a dead stop, sometimes it's difficult to put it into first gear. After having to press on my clutch twice it finallys goes it, but sometiems i have to force it in.
Does anyone know what the problem might be?
Old Jan 25, 2005 | 02:21 AM
JonnySBeee...'s Avatar
Default Re: 1st gear problem (rIceNOodles)
it use to happen all the time with my integra. but with my accord it happens every once in a while. i put it back in neutral then back into first until it goes in
Old Jan 25, 2005 | 03:33 AM
raceACCORDingly's Avatar
this happens to me in reverse alot. i gotta step on the clutch and slowly release it while putting it in gear or go into another gear before reversing. i think its the shift fork.
Old Jan 25, 2005 | 06:07 AM
srfnscubamunkey's Avatar
Default Re: (raceACCORDingly)
if it gets worse replace your slave cylinder
Old Jan 25, 2005 | 08:31 AM
JimBlake's Avatar
Default Re: (srfnscubamunkey)
Might be even simpler than that. Air bubbles. Bleed your clutch first.
Old Jan 25, 2005 | 11:48 AM
i20ar's Avatar
i have the same problem usualy i either double clutch or give it a lil rpms to slip it into gear .
Old Jan 25, 2005 | 12:34 PM
biggs2.3's Avatar
Default Re: 1st gear problem (14aZnS)
i say that there is no proble it is harder to put it in first because when you stop those gears don't alway line up straight so you might have to pop it in second or third befor it will go into first or reverse
Old Jan 26, 2005 | 10:18 AM
so im guessing this is a normal problem then. Thanks for all the replies.
Old Jan 26, 2005 | 01:01 PM
TOAB's Avatar
synchro's probably.
stick it in 3rd, then right to 1... see if that helps.
wascly
Transmission & Drivetrain
Aug 22, 2013 09:50 AM
donepps
Apr 6, 2013 09:36 AM
migueldiaz
Honda Civic (2006 - 2015)
Jul 30, 2011 04:41 PM
Villenurve
Oct 12, 2007 09:58 AM
dude100
Honda Motorcycles
Oct 1, 2004 08:10 PM
