time for a new clutch
Old Jan 24, 2005 | 10:41 PM
JDM_Type-R's Avatar
Default time for a new clutch
well, its about time for a new clutch since its been slipping here and there. i was just wondering what i would be needing. a friend tells me i should also get my flywheel resurfaced, but personally i have never heard of it. is it really necessary? i guess all in all what i wanna know is what i need to change my clutch besides the clutch. any info appreciated. thanks.
Old Jan 24, 2005 | 11:11 PM
B2FiNiTY's Avatar
Default Re: time for a new clutch (JDM_Type-R)
How many miles do you have?
You can take the chance to install a FD.
You can also change the following depending on the condition of your parts
- resurface flywheel
- new flywheel pilot bearing
- throwout bearing
- shift fork
- driver and passenger axle seals
Old Jan 24, 2005 | 11:17 PM
JDM_Type-R's Avatar
Default Re: time for a new clutch (B2FiNiTY)
id do dennis IDB!!
Old Jan 24, 2005 | 11:21 PM
JDM_Type-R's Avatar
is resurfacing the flywheel necessary?
Old Jan 24, 2005 | 11:26 PM
B2FiNiTY's Avatar
Depends how bad it is.
Old Jan 24, 2005 | 11:31 PM
KayOs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R &raquo;</TD></TR><TR><TD CLASS="quote">is resurfacing the flywheel necessary?</TD></TR></TABLE>
Doesn't hurt to do it.
Old Jan 24, 2005 | 11:34 PM
JDM_Type-R's Avatar
Default Re: time for a new clutch (KayOs)
u have a point
Old Jan 25, 2005 | 05:02 PM
JDM_Type-R's Avatar
okay so...does anyone know which parts all together will be necessary to replace the clutch?
also, anyone know where is the cheapest for the OEM setup?
is it len @ baranco?
how much am i looking at..?
i think im going with jdm final drive too
Old Jan 25, 2005 | 05:12 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">
- throwout bearing
- shift fork
- driver and passenger axle seals</TD></TR></TABLE>
Didnt he say thats whats reccomended to inspect?
If you dont already I reccomend you get a Helm manual. I'd hope you're not going to attempt to do this (for what appears to be your first time) without one.
Also go to http://www.acuraautomotiveparts.org but you should already know this since someone asks about OEM parts every freaking 15 minutes. Also why dont you PM Len if you already know his connection instead of asking us? A call to the local Acura dealer isnt that hard either.
Old Jan 25, 2005 | 05:22 PM
JDM_Type-R's Avatar
Default Re: time for a new clutch (KOALA YUMMIES)
or you can learn how to read
i asked...does anyone know which parts all together will be necessary to replace the clutch?
not what i need to inspect u dummy
and yes i plan on contacting len, its just that i plan to keep my options open u ***
i guess my main question is ..what oem product #'s will i need to replace the clutch
Old Jan 25, 2005 | 05:41 PM
If you knew anything about cars you'd know that not everything needs to be repalced. You need to INSPECT:
1. the lining of the clutch disc for signs of slipping or oil. If it is burned black, or oil soaked REPLACE
2. Measure clutch disc thickness New: 8.3-9.0mm Limit 6.0mm
3. Measure depth from the lining surface to the rivets, on both sides. New 1.2-1.7mm Limi .2mm
Flywheel: INSPECT:
1. Ring gear teeth for wear and damage.
2. Inspect clutch disc mating surface ont he flywheel for cracks, wear and burning.
3. Measure flywheel runout using a dial indicator through at least two full turns. Push against the flywheel each time you turn it to take up the crankshaft thrust washer clearance. New: .05mm Limit .15mm
Straight from the Acura Helm manual NOT ALL OF THE INFORMATION FOR FLYWHEEL REPLACEMENT. See you doofus, its not all replace. There is a LOT of inspecting.
You'll also need a clutch alignment disc, ring gear holder, alignment shaft, and many more tools, that you'd know you needed if you had a service manual.
Old Jan 25, 2005 | 05:50 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">If you knew anything about cars you'd know that not everything needs to be repalced. You need to INSPECT:
Flywheel: INSPECT:
good info also for the poster, if your going to be replacing the clutch why not just get a better performing clutch instead of a OEM clutch and a aluminum flywheel?
Old Jan 25, 2005 | 05:55 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: time for a new clutch (totsie7944)
If your flwheel hasn't been scored, and it is still very smooth, like a new rotor, take some 1000 grit sandpaper and EMORY it, as they call it.
then take alcohol and clean the flywheel and you are set
Old Jan 25, 2005 | 06:11 PM
B2FiNiTY's Avatar
Default Re: time for a new clutch (MugenHonda)
If your not making gobs of power or requiring something to handle the beating you give it, the oem clutch is great.
I was making around 190whp and the stock clutch with aftermarket flywheel was perfect for me.
Also, if you are going to tackle this job yourself, be equiped with a proper tq wrench and clutch alignment tool
Old Jan 25, 2005 | 06:17 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">If your not making gobs of power or requiring something to handle the beating you give it, the oem clutch is great.
Also, if you are going to tackle this job yourself, be equiped with a proper tq wrench and clutch alignment tool </TD></TR></TABLE>
good call, clutch alignment kit is a must.
Old Jan 25, 2005 | 06:19 PM
HondaRcB's Avatar
Most clutch kits I'm aware of come with the alignment tool. I assume OEM doesn't however.
Old Jan 25, 2005 | 06:22 PM
B2FiNiTY's Avatar
Default Re: time for a new clutch (HondaRcB)
I know that act, clutch masters, spoon, and a few others do not include the tool. For act, they actually sell a plastic one.
Old Jan 25, 2005 | 08:35 PM
HondaRcB's Avatar
My ACT, bought last December, came with one.
Old Jan 25, 2005 | 08:42 PM
99 TYPE R's Avatar
Act is teh way to go for street, now you should buy my brand new flywheel and clutch kit, lol
Old Jan 27, 2005 | 12:36 AM
JDM_Type-R's Avatar
Default Re: (99 TYPE R)
when replacing the clutch..would you generally need to replace all 4 of these after 50K miles?
friction disk
pressure disk
throwout bearing
pilot bearing
or just the friction/pressure disk?
B_Swapped93
Apr 4, 2013 06:30 PM
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
FuNkDrSpOt
Oct 7, 2007 02:08 PM
aZnjCC
Mar 6, 2006 07:09 AM
