Fully built B20 Vtec how is the milege?
Wat up yall, I'm just wondering how many miles can you get out of a fully built B20 with GSR heads? thats what i'm planning to get soon, i'm curringly running a 2000 EX couple with stock d16Y, any advise apreciated.
Thanks
Romeo
Thanks
Romeo
1009382837823742347283947293847 billion miles..
Common man THINK!
A motors life depends on how you treat it. if you beat the **** out of it every second of its life.. wont live to long. but if u take care of it and maintain it properly it could last a long time. it also depends on how well u built it. did you half *** the motor or was it done the right way all the way through?
Common man THINK!
Thanks for the quick reply G, well I know it could be reliable, but what I mean is how often I have to fill up the gas tank if I have a fully built b20, meaning new cams, port polish the whole nine yard work on the motor with 0 miles on it, how many miles per gallon can you get out of that ****?
what is your compression ratio?
what size injectors?
fuel pressure?
what kind of management system are u using?
how well did you tune the car?
what is ur air fuel ratio?
Think things through b4 you ask your question bro
fuel pressure?
Thanks, thats all I need to know I gues i'm new at this **** and everybody want flame me, but its all good. Anyways have you Dyno your motor? what hp and tq have you pull out of it?
yea i got it dynoed but i need some other things to get it where it should be it made 205 hp and 155 tq, i need a 2.5 inch header, and also a bigger throttle body and port matched, and i didnt mess with the cam gears at all they were at 0,0, and also im probably gonna throw in some bc4 cams, then maybe ill be able to get to my goal of 230 hp and 160 tq......................... DREAMS >><<>><<>><<&g t;>
Powered by Rowena Galam
27
May 23, 2019 12:14 PM
bseriesboosted
Oct 1, 2003 09:32 AM
johnzm
May 15, 2003 02:03 PM
