how long would a b20/vtec motor last?
Old 01-12-2003, 09:56 PM
Powered by Rowena Galam's Avatar
Default how long would a b20/vtec motor last?
how long would a b20/vtec motor last? mileage wise w/ a gsr head and gsr tranny?
how long would it last if it was turbo charged?
Old 01-12-2003, 09:59 PM
eg_nezay's Avatar
Default Re: how long would a b20/vtec motor last? (Powered by Rowena Galam)
It all depends who builds it and what parts u used. Get someone that knows what they are doing and that are recommended by others.
Simple's Avatar
im hoping a LONG time, because i just got mine with like 8-9 thousand miles on it, but its got an LS trans.. i think itll last.. friend has one.. has had it for a long time, and runs it to death, hes got a GSR trans... hes turbo'ing it soon.. so i think they are fairly stable for a pretty long while.. try a search
Old 01-12-2003, 10:01 PM
Downey's Avatar
all depends on how its built and how you drive it. build it good, dont cut corners and dont live at 9000rpm and it should last a long time. but that doesnt mean u still cant fun!
[Modified by Downey, 11:02 PM 1/12/2003]
Old 01-12-2003, 11:28 PM
NW94RS
Guest
Posts: n/a
Default Re: how long would a b20/vtec motor last? (Downey)
for sho
dont cut ANY corners and get someone thats recomended.
Old 01-13-2003, 12:20 AM
blackANESE's Avatar
Default Re: how long would a b20/vtec motor last? (DC-2R)
2-3 weeks tops. Those motors suck!
Old 01-13-2003, 05:57 AM
Ya@inlinePRO's Avatar
Default Re: how long would a b20/vtec motor last? (blackANESE)
hahaha, just get a block resleeved and bored out to 2.0 L, the stock b20 got weak sleeves...it sucks when you take the head off and you see broke sleeves... good luck.
Old 01-13-2003, 06:41 AM
ProEater's Avatar
Default Re: how long would a b20/vtec motor last? (kwik2nec)
ive heard that a properly done ls/vtec starts to have problems by 20k if it last that long.
EDIT: not too sure about turbo. prolly 1/2 the life of a average ls/vtec
[Modified by ProEater, 7:41 AM 1/13/2003]
Old 01-13-2003, 09:03 AM
Future Texas Boy
vtecvoodoo's Avatar
vague question. depends on the builder, mods, etc.
Old 01-13-2003, 09:06 AM
black2kcivic's Avatar
Default Re: how long would a b20/vtec motor last? (vtecvoodoo)
Also depends on how you drive it, being that none of us are you we don't know the awnser to that question.
Old 01-13-2003, 09:11 AM
nick.na's Avatar
Default Re: how long would a b20/vtec motor last? (black2kcivic)
drive with caution and build quality...be sure to get it sleeved and enjoy for long time
Old 01-13-2003, 09:21 AM
Mocky57's Avatar
Default Re: how long would a b20/vtec motor last? (ProEater)
20,000? life is that short? i'm new to hybrid/engine mods.
Old 01-13-2003, 09:24 AM
Moderator
chad's Avatar
wErd
the 4 i have had built lasted me less then 5000 miles....one blew up on the first trip less than 100 miles.
crappy builders across the line......they said 100 dollar....i said ohkay....i guess you get what you pay for
and if you do a search on this subject you'll find i'm full of crap....i have 20k on mine
Old 01-13-2003, 09:35 AM
DJ KrunchyKracker's Avatar
Default Re: how long would a b20/vtec motor last? (chad)
there is no real limit on how long they last. it all depends on your maintenence habits and how well it was built/taken care of from the begining. if u dont rev to the moon all day and you meticulously keep it clean and serviced your engine life will be long and prosperous. and be sure to do a big burnout everyday. unless u r a burnout in which case u only have to do one once every 3 days.
Old 01-13-2003, 09:56 AM
rsxgirlie's Avatar
if it's stock bottum end.. i would say 50k for sure.. if it's built.. like 15k ... with a turbo the sleeves will crack.. so.. hehe
how u drive is a big factor !
i would boost an ls/vtec before a crvtec... if built right and tuned right it will run for a while... definetly longer than 20k
Old 01-13-2003, 11:26 AM
blackANESE's Avatar
Default Re: how long would a b20/vtec motor last? (rsxgirlie)
I love all the horror stories people hear. "My friends neighbors cousin's good friend had an ls/vtec and it only lasted 15k."
Use quality components and it will last a long time.
My friends ls/vtec that he built lasted 20k with no problems, he then put in a fully built b20. They last, just don't rev to astronomical heights.
Old 01-13-2003, 09:07 PM
Moderator
chad's Avatar
8000-8500 rmps daily.....is that reving to the moon?
Old 01-13-2003, 09:12 PM
SiBirdie's Avatar
8k is fine and 8500 is fine, 9000-10000 is really really high and recommend a block gridle.
Old 05-14-2019, 06:46 AM
Paul barnum's Avatar
I have a completely bone stock b20 bottom end with a b16 head all I have is skunk2 springs and Retainers Got my car dyno tuned at xenocron tuning solutions I been reving up 7800k and so far I been running it pretty hard for about 16,000 miles. Not sure if it makes any difference For longevity but I've been using Valvoline 5W30 Full synthetic for oil And a court of Lucas full synthetic Oil stabilizer
Old 05-14-2019, 07:16 AM
Fish Twig
tony_2018's Avatar
probably won't last long, the bottom end was only built to rev up to 6-7k rpm.
Old 05-15-2019, 12:05 PM
RonMexico420's Avatar
Mine lasted about 8,000 miles on the stock sleeves with cast pistons jdm b16 pistons. Complete fresh rebuild and the engine was broken in on the dyno. Went back 3 months later for a follow up tune. Only got on it a handful of times and all the A/F were good or seemed good. 2 Sleeves ended up cracking a month ago.
Old 05-15-2019, 07:32 PM
JRCivic1's Avatar
All motor ???
Old 05-16-2019, 12:16 PM
Yes sir. All motor. Another thing I forgot to mention was that the entire roating assembly was balanced as well. The stock sleeves really do suck. Some last a very long time and others not so much. It's a toss up really.
Old 05-16-2019, 09:14 PM
JRCivic1's Avatar
It is pretty rare to crack a sleeve in a NA "B" series engine... certainly as the primary failure anyway. A properly assembled and tuned LS/Vtec engine has a very good chance of long term survivability.
Old 05-17-2019, 06:59 AM
I agree. The sleeves were bored to 84.5 for the rebuild so they were getting a little thin. Deceided to go the LSV route this time instead of the B20V.
Quick Reply: how long would a b20/vtec motor last?
