TPS question
Old Jan 24, 2005 | 05:58 PM
PHILLIPDEEZ's Avatar
Default TPS question
my idle fluctuates between 1000 and 1600 rpm and i have the IACV screwed al the way i did some searching and i guess i need to reset the TPS my question is my friend has a throttle bodyon his old motor with the TPS on it cna i just take his whole throttle body and put that on wiht haveing to set the tps cuase i dont have a volt gauge to set mine and i dont wanna put out anymore money to have my car fixed by someone else
Old Jan 24, 2005 | 06:05 PM
lazynok's Avatar
Default Re: TPS question (PHILLIPDEEZ)
if your original tps has NEVER been removed it is NOT the tps. look elsewhere... thats why they put those screws on there so you never **** it up,
but if needs be.. you will need a voltmeter. I can not set mine cause i don't have a volt meter... but if i tilt it all the way one way... my car idles at ~100rpm.. and all the way at the other side i idle at ~900rpm,. i need a volt meter...
hope that helped. get a voltmeter
o'malley_808
Aug 6, 2009 10:24 AM
deetz84
Sep 22, 2006 06:17 PM
kpdandav
Nov 4, 2005 07:44 PM
RCautoworks
Jun 6, 2004 08:48 AM
Kendall
Mar 20, 2004 07:23 PM
