Head removal on 93 ex
i unbolted the exhaust manifold, and removed all the head bolts, timing belt, and all the vaccum and fuel lines, is there a mount or something holding the intake manifold down, i can see something but i cant get to it.
Modified by dblock91 at 3:07 PM 1/25/2005
you need to get below/under the motor and you will be able to see if from the underside. the manifold is bolted to the block, by this bracket. you should be able to remove it from above too i believe if you are tricky
only problem is the car is in a field sitting on the ground, so getting under is gonna be a problem, hopefully i can work it out from above
yohimbine
Jul 31, 2013 04:45 PM
Untamed_Hatred
15
Jan 30, 2008 08:29 AM
