Hom many bolts are there on the intake manifold
I ned to know where all the bolts are holding the intake manifold to the head i got all the ones on the top of it, the 2 on the botton mount and 2 that are on the sides are there any more and what is the trick to getting it off
Re: Hom many bolts are there on the intake manifold (Untamed_Hatred)
The trick is to also take off the support bracket on the bottom that is also attached to the block. Look right above your oil filter.
its a d16z6 sorry for not specifying. i got 4 off the top 2 off the sides and 2 off the bracket but its still being held down by something somewhere
Re: (Untamed_Hatred)
i know it is pain in the butt to remove intake manifold cause i just replaced mine too..took me and a friend 1 hour to get it out and 45 mins to get it in with power tools..
i got all the bolts out that need to be taken out but the manifold is still stuck to the head. i have tried banging on it, prying on it but its still stuck, and is it completely necessary to take it off wwhen replacing a head gasket
PHANTOM MENACE
Re: (D50boy)
As stated you don't need to remove the intake manifold, but it sounds like you missed the nut in the middle (it's behind the black hose, you can see the bottom half of it):
not trying to hijack over here but I'm having a problem with taking off the intake manifold is there any tools or things i should use to take it off? and its a D16Y8 manifold i used pj blaster or something of that and the only things that happening is the bolt is getting strip so what should i do?
vtecftw
04-22-2007 10:28 PM
