Question on running wires..
Old Jan 24, 2005 | 05:13 PM
russellfx's Avatar
Default Question on running wires..
I just installed these LED windsheild washer fluid lights. I got the fluid to run through them and squirt on the windsheild but the wires i need to run through the dashboard into the car through the engine. I have a Honda Civic 1999 LX 4-door. How would I be able to run the wires through into the car so I can plug it into a transformer type of thing which plugs into the cigarette lighter? Thanks!
-Russell
Old Jan 24, 2005 | 06:19 PM
crxtreme89h's Avatar
Default Re: Question on running wires.. (russellfx)
You will have to find a rubber gromet in your firewall to run it through. You might want to ask the guys who have this model of car. Unless someone here knows where to locate a gromet. Use a wire hanger to get the wire through from one side to the other. Use electrical tape and tape the wires to the wire hanger. Run the hanger and the wires parallel together so there is less resistance when you push the hanger and wires through the gromet. You may have to cut the gromet a little with a razor knife or the like. Careful not to cut any wires or anything else that may be already going through that gromet.
Old Jan 24, 2005 | 06:53 PM
crxvtecturbo's Avatar
* B A N N E D *
Default Re: Question on running wires.. (crxtreme89h)
why would you want ricer stuff on your car
Old Jan 24, 2005 | 07:09 PM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
I know to each is own, but why?
stevenr2894
10
Mar 9, 2013 10:23 AM
raphael
May 26, 2006 07:24 PM
terboracer
11
Jan 15, 2005 09:40 PM
one slow coupe
Dec 26, 2004 12:24 PM
FastNFurious
Jun 14, 2003 06:42 AM
