ummm... duhhh...
Old Jan 24, 2005 | 01:56 PM
shai x boi racer's Avatar
Default ummm... duhhh...
hey guys... I have ... I think a 91 ls tranny... i was trying to figure out where the transmission fluid goes...
so ... a few questions...
1. there are like 4 bolts on top including one that looks like a dip stick hole that has a cover on it. and I know where the drain bolt is... but there is a bolt that that you can insert a 1/2 wrachet in and a bolt w/ six sides that works the same as the first bolt. about the same height. both are hard as hell to take off.. so which hole is it?
2. whats the difference between atf and mtf... since my car didnt work I had my brother get me MANUAL transmission fluid... and he came home w/ A t f... just wondering the difference.
thanks...
Old Jan 24, 2005 | 03:01 PM
]{iwi's Avatar
Default Re: ummm... duhhh... (shai x boi racer)
dont put atf in ur tranny use 10W-30 motor oil and u can fill it from a few spots theres a bolt right above where u drain the tranny
Old Jan 24, 2005 | 04:07 PM
Default Re: ummm... duhhh... (]{iwi)
but that bolt is six sided ... like the one like the bolt next to it... and its an inward... its not even a bolt...
Old Jan 24, 2005 | 04:13 PM
ServiceAdvisor's Avatar
http://www.we-todd-did-racing....D.jpg You have to remove the starter to see it. - Darrell
Old Jan 24, 2005 | 04:40 PM
Default Re: (DOHCZCCRXSi)
yea... but that bolt looks shallow it looks like it could also be REALLY hard to take off... I dont want to spend several hours taking off a bolt that would just strip and have wasted time on my hands
Old Jan 24, 2005 | 04:44 PM
slowman's Avatar
I took way too long
Default Re: (shai x boi racer)
To drain, there is a bolt below the axle, it is a recessed square, take your ratchet and stick it in.
When that is complete there is a bolt directly Northwest of there, about even with your axle, thats where you fill it. I believe it's a 17mm? Not sure can't remember.
Get a funnel and put some vaccum hose on the end and pour whichever kind of lubricant you prefer in!
BTW, it's all on your passenger side JIC.
Old Jan 24, 2005 | 06:24 PM
crxtreme89h's Avatar
Default Re: (slowman)
I'm not sure about the LS tranny, but if it's anything like the B16 trannies you can fill the tranny from the VSS (vehicle speed sensor) hole located on top of the tranny.
Old Jan 25, 2005 | 05:05 PM
Default Re: (crxtreme89h)
that vss is only for 94 + vehicles i think for hydro clutches becauase... the earlier years have a different sensor set up.
Old Jan 25, 2005 | 05:10 PM
kurinto's Avatar
Pic here http://www.honda.co.uk/owner/C...2.pdf
Old Jan 25, 2005 | 06:45 PM
WhiteDSM520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shai x boi racer &raquo;</TD></TR><TR><TD CLASS="quote">that vss is only for 94 + vehicles i think for hydro clutches becauase... the earlier years have a different sensor set up. </TD></TR></TABLE>
No, all d and b series have the same basic speed sensor. It's just some have an electronic sensor at the top of them and others have a cable coming out. Take the 2 or 3 10mm bolts out, yank the sensor out and fill it from there. That's what I've always done and it works fine. BG or honda MTF works the best.
aznromeo4u
Feb 24, 2015 02:52 PM
doom26464
Jun 18, 2008 07:10 PM
dcrbin22
Sep 15, 2004 10:38 AM
asubennett
Aug 21, 2003 05:14 PM
RCautoworks
Feb 16, 2003 11:16 PM
