vtec solenoids the same
Old Jan 24, 2005 | 01:24 PM
ebrakeracin4's Avatar
Default what vtec solenoids the same?
What solenoids are the same? I have a gsr and I think i have a bad one. I do know that the y8 is dif. but dont know about the rest.
Old Jan 24, 2005 | 05:36 PM
00000xxx's Avatar
Default Re: what vtec solenoids the same? (ebrakeracin4)
a d-series vtec solenoid will work on a b-series motor, so a b-series vtec solenoid will work a b-series motor, only big differnece is if its a JDM or USDM vtec solenoid, get a USDM vtec solenoid and you'll be fine, you can run jdm and usdm ecu's and hit vtec, just get one off another b-series or d-series motor not sure about h-series though..... i used a d-series vtec solenoid on my B16B and works like a champ, later on
Old Jan 24, 2005 | 07:21 PM
PrettyLude's Avatar
u sure a d series vtec solenoid will work on a b series?
Old Jan 24, 2005 | 08:12 PM
tpntchcrz's Avatar
Default Re: (PrettyLude)
i used my d series on my b16 and it works just fine just change the seal
Old Jan 24, 2005 | 08:14 PM
HONDA_TYPE_R's Avatar
I don't think a d-series will work on a b-series. I ran into this issue when I was doing my b16 swap. I think you should just use the solenoid meant for the b-series.
I heard somewhere that using a CTR solenoid will improve performance...I have seen no further evidence to back up this claim.
Old Jan 25, 2005 | 04:18 AM
mr.beeks's Avatar
Default Re: (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">
I heard somewhere that using a CTR solenoid will improve performance...I have seen no further evidence to back up this claim.</TD></TR></TABLE>
the solenoid only controls the oil passage to activate vtec nothing else
so its just hype....
Old Jan 25, 2005 | 03:51 PM
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">
so its just hype....</TD></TR></TABLE>
I kind of figured that...I just needed an expert to say yes or no. Thanks!
Old Jan 25, 2005 | 04:30 PM
GDM Z28's Avatar
im using a d seriesone on my ls/vtec and it works fine
Old Jan 25, 2005 | 05:23 PM
mmuller's Avatar
Mad Scientist
all b-series are the same, besides the 1gen b16 heads, wich is different.
you can use a D series vtec spool and sol. on a B series; but the vtec oil pressure switch will be pointing towards the fromt of the car.
Old Jan 25, 2005 | 10:14 PM
GDM Z28's Avatar
Default Re: what vtec solenoids the same? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">all b-series are the same, besides the 1gen b16 heads, wich is different.
yup mine points forward....looks like my motor has a little boner
Old Feb 28, 2005 | 02:42 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
can i use a solenoid from a d16z6 on a p72 gsr head. will the presure switch hit the water neck
Old Feb 28, 2005 | 06:19 PM
boost fed ls's Avatar
Default Re: what vtec solenoids the same? (TURBO BLUE HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO BLUE HATCH &raquo;</TD></TR><TR><TD CLASS="quote">can i use a solenoid from a d16z6 on a p72 gsr head. will the presure switch hit the water neck</TD></TR></TABLE>
I have a p72 head and want to know as well bcause I am having a hard time finding a used spool assembly. You cant just buy it alone, you have to get the oil press sensor, vtec solenoid and spool assembly as a complete unit. anyone have one for sale?
The people that have used a d-series spool assemblu on a p72 head please comment.
Old Feb 28, 2005 | 07:14 PM
neogenesis2004's Avatar
Default Re: what vtec solenoids the same? (boost fed ls)
me and turbo blue have been researching this together and have come up with a definate yes to the soleniod on the d16z6 being compatible
HRubss
May 10, 2016 06:49 PM
blivic
Feb 8, 2007 11:53 AM
ss20gsr
Mar 2, 2004 10:03 PM
1hottEG6
Feb 20, 2003 11:02 AM
