auto to manual question
Old Jan 24, 2005 | 01:15 PM
Zach L's Avatar
Default auto to manual question
this past weekend i swaped my tranny to manual and got a new motor.... now right now i have a CEL thats saying the "torque converter" is messed up or something around there. now how do i tell or convince the ECU to think i dont have a torque converter anymore... thanks alot for any replys...i need to figure this out asap cause my inspection is out PLEASE HELP
Old Jan 24, 2005 | 01:17 PM
nocturnaldragon's Avatar
Default Re: auto to manual question (Zach L)
To my knowledge you need a different ECU, but ill check on the wiring once to see if theres something you can jump but i dont think so
Edit: i did a quick check and i belive you need an ecu for a manual trans
Old Jan 24, 2005 | 01:24 PM
Street Ghost's Avatar
what ecu are u using?
Old Jan 24, 2005 | 02:22 PM
2fast4u831's Avatar
I'm really 2slow
Get a 5 speed ecu man.
Old Jan 24, 2005 | 02:44 PM
GdmLaz's Avatar
u could chip ur ecu to make it manual for cheap
Old Jan 24, 2005 | 02:46 PM
gotboostedvr6's Avatar
Default Re: (2FAST4U831)
you can modify the ecu itself to fix the cel. I believe that you have to remove a resister and solider in a jumper. If u search along those lines you'll find a few posts and btw the fix is simple its not more than mabe a 5min job.
-dave
Old Jan 26, 2005 | 09:19 AM
RICE POLICE SIP's Avatar
Default Re: (gotboostedvr6)
if it's a non vtec engine then just get a manual PO6 ECU. They're pretty cheap since (almost) nobody uses them and if you have a VTEC engine then buy a manual P28... But even then the CEL shouldn't harm the way your car runs...
Old Jan 26, 2005 | 10:34 AM
evilsolb16's Avatar
Default Re: (Split Image Prez)
remove rp17 and rp18 from ecu and jump rp18 that sould get rid of the cel
Old Jan 26, 2005 | 01:16 PM
one8toh8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zach L &raquo;</TD></TR><TR><TD CLASS="quote">this past weekend i swaped my tranny to manual and got a new motor.... now right now i have a CEL thats saying the "torque converter" is messed up or something around there. now how do i tell or convince the ECU to think i dont have a torque converter anymore... thanks alot for any replys...i need to figure this out asap cause my inspection is out PLEASE HELP</TD></TR></TABLE>
dude just save the trouble you will end up going through and just get a manual ecu (Ebay they are cheap)
Fook_me_honda
Jan 9, 2008 11:58 PM
deeweezy187
Aug 19, 2007 10:37 AM
purple98ek
May 8, 2007 10:44 AM
Street Sweeperz
Dec 16, 2006 09:03 AM
rleroy
11
Aug 29, 2005 10:07 AM
