obd2-obd1....chipped p28
Old Jan 24, 2005 | 10:23 AM
CNSK's Avatar
Default obd2-obd1....chipped p28
I have a 00 civic with with 96 jdm itr engine....anyways, im currently running a 00 p73 ecu obd2....everything seems to operate correctly with the exception of having the cel on becuase of the remove immobolizer. Well anyways, I bought a obd2b ecu jumper and bought a custom mugen spec p28 ecu. Now when I hook it up, my rpm would flucuate from 100-1200 rpm. what could be the problem? I cleaned my iacv and check all hoses and seems fine. I then tested the ecu on my buddy 95 teg and everything operates correctly on his car....if anyone could give me some advise, I would greatly appreciated...thanks...
Old Jan 24, 2005 | 10:34 AM
2lua's Avatar
Default Re: obd2-obd1....chipped p28 (CNSK)
did you reset the ecu? did you let it idle for 5 min without pressing gas pedal or turn on any accessories? if it work on your friend car fine the you should check the fitv.
Old Jan 24, 2005 | 01:08 PM
CNSK's Avatar
fitv? I did reset the ecu...and let it idle for a over 10 min....still flucuates.....plus I adjusted the throttle needle and seems to just rev up and down even higher...from 100-1500.....I dont know.....could be some leek hoses somewhere that i couldnt find...any more suggestions....thanks
Old Jan 24, 2005 | 01:22 PM
2lua's Avatar
fitv = fast idle thermo valve. you need to set you tps back to spec. .45v at idle and 4.5v wot. check your throttle cable to see if it is too tight.
crxb16a90
Engine Management and Tuning
Mar 4, 2011 02:06 PM
mtownsi
Apr 14, 2006 05:54 AM
mikeunreal2
31
Mar 12, 2006 10:28 PM
