detachable steering wheel and SRS (searched)
Old Jan 23, 2005 | 10:41 PM
Do_Ster's Avatar
Default detachable steering wheel and SRS (searched)
hey guys i just had a few questions. when adding a detachable steering wheel to an SRS equipped car, the SRS light comes on because you have to unplug the plug. now, does that only disable the driver side airbag because that is the one that is unplugged or does it disable both driver and passenger airbags? i'm not quite sure, i think once a long time ago someone told me that both would be disabled sense the SRS is one unit. also if it does disable both driver and passenger, is their a work around to have at least the passenger airbag working?
i am still debating on whether or not to get a detachable steering wheel, for obvious theft deterent reasons but also safety issues regarding the SRS is leaning me the other way. some more info would be greatly appreciated. thank you
Old Jan 23, 2005 | 11:01 PM
Andres-eh2's Avatar
My friend installed a Sparco wheel on his civic. A couple of months later he has an accident and the passenger one deployed. I will ask him if he did something to it. 96 DX if it matters...
Old Jan 24, 2005 | 08:57 PM
Do_Ster's Avatar
cool thanks, anyone else?
Old Jan 25, 2005 | 08:00 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (ntogethernow)
This HKB hub adapter has an electrical connection inside to retain full function of your SRS system without the drivers side airbag. It will also keep your SRS computer from throwing codes and lighting up the SRS light.
Click Here
Old Jan 25, 2005 | 09:52 AM
Do_Ster's Avatar
thanks for the link, but i was looking to get the tekniq system. anyone know if that one has the SRS connection that 94eg is talking about?
Old Jan 25, 2005 | 10:50 AM
94eg!'s Avatar
#1 Super Guy
Loved
You will still need a hub adaptor before you can add a steering wheel quick release. The quick release portion is suposed to bolt between the new hub and the steering wheel, while the hub is designed to bolt directly to the factory steering column splines. Oops, did the price of a removable steering wheel just jump way up?
Old Jan 25, 2005 | 11:21 AM
igo4bmx's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">You will still need a hub adaptor before you can add a steering wheel quick release. The quick release portion is suposed to bolt between the new hub and the steering wheel, while the hub is designed to bolt directly to the factory steering column splines. Oops, did the price of a removable steering wheel just jump way up? </TD></TR></TABLE>
a hub is only 50 bucks
BoostedH
Nov 17, 2017 07:31 AM
d4rk13l4de
Feb 26, 2009 08:03 PM
B20EF
May 3, 2008 09:17 PM
Menatep
Mar 11, 2007 12:41 AM
mtber
Nov 7, 2003 09:00 PM
