WTF? Blinking CEL?
Old Jan 23, 2005 | 08:31 PM
D50boy's Avatar
Default WTF? Blinking CEL?
I never know he CEL will blink. For some reason it is. Anyone know why it would start flashing?
Background:
99 Civic hatch with B18C5 swap. Running an older ITR ECU with a Kenji OBD harness. I was getting cylinder misfire codes at idle. It's been lit for that reason for a while. Motor sounds fine. Still wants to idle low..... if I turn on the AC, idle sometimes compensates.... sometimes it won't and acts shitty at 500rpm. On the highway its fine.
Any ideas?
Old Jan 23, 2005 | 08:34 PM
civictildeath's Avatar
Default Re: WTF? Blinking CEL? (D50boy)
what is it blinking?? it will blink out numbers then a pause (like 2-3 seconds) then blink some more. count them and let us know
Old Jan 23, 2005 | 08:43 PM
huntarrr's Avatar
Default Re: WTF? Blinking CEL? (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">what is it blinking?? it will blink out numbers then a pause (like 2-3 seconds) then blink some more. count them and let us know</TD></TR></TABLE>
Umm it will only blink like that if you use the jumper. I dont think this is what he's doing.
I imagine there either some sort of wiring problem or bad sensor (o2 maybe?). I know that my CEL used to come on for little while and then go off. It was giving the code of a bad cat converter (or secondary o2, can't remember). Check to see if you can pull up the code by any chance (get the P code from autozone) and that'll help out to diagnose the problem.
Old Jan 24, 2005 | 11:09 AM
D50boy's Avatar
It is a steady flash which is why I found it strange.
My car is so frankenstien I'm not sure which scan tool to use
Old Jan 24, 2005 | 11:50 AM
skip.two's Avatar
ECU thread.
https://honda-tech.com/zerothread?id=682412
its the third thread in this forum.
Old Jan 24, 2005 | 11:55 AM
mct121's Avatar
I have seen my CEL blink when I was getting misfires due to worn out plug wires. The guy at the Honda dealership told me that a blinking CEL means to pull over and shut the car off immediately. I have not verified this statement anywhere, so take it for what it is worth.
Old Jan 24, 2005 | 12:03 PM
skip.two's Avatar
Default Re: WTF? Blinking CEL? (mct121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">The guy at the Honda dealership told me that a blinking CEL means to pull over and shut the car off immediately.</TD></TR></TABLE>
he probably said that because a CEL could mean a lot of things. if its something major and you keep driving on it, then you can seriously damage your engine.
Old Jan 24, 2005 | 03:46 PM
XX Boosted Si XX's Avatar
Default Re: WTF? Blinking CEL? (jL iLLuZiOnz 9)
my CEL started blinking and then 2 days later....POP...there goes the motor...
Old Jan 24, 2005 | 03:53 PM
Ricey McRicerton's Avatar
Default Re: WTF? Blinking CEL? (XX Boosted Si XX)
Blinking CEL is random misfires.
Old Jan 24, 2005 | 04:11 PM
tealbubble's Avatar
Default Re: WTF? Blinking CEL? (Ricey McRicerton)
search it, i've seen tons of posts on it.... it also happens if you leave the paper clip in your ecu when your scanning for codes.... bump
Old Jan 24, 2005 | 09:11 PM
D50boy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XX Boosted Si XX &raquo;</TD></TR><TR><TD CLASS="quote">my CEL started blinking and then 2 days later....POP...there goes the motor...</TD></TR></TABLE>
Don't tell me that!!!
Random misfires. Crap. What would cause that? It's always done it since I've had the car. Just the idle has been funky. New cap, rotor, plugs and wires. Could the timing be screwy?
Old Jan 24, 2005 | 10:05 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Blinking CEL is random misfires. </TD></TR></TABLE>
When I put my spark plug wires on in the wrong order it did that (constant blinking) scared the **** out of me, I turned the car off quick, all I was thinking is 'Blinking CEL... that can't be any good'. I would suggest double checking you timing and firing order with the dist.
DC2-ProdUcTiOnS
May 7, 2014 12:04 PM
Baron55
Acura TSX
Jul 8, 2009 12:22 PM
tweekerz
Nov 27, 2006 03:22 AM
TylerC
Aug 18, 2005 10:28 PM
