Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Idle problem
Old Jun 21, 2009 | 10:09 PM
Baron55's Avatar
Default Idle problem
this weekend I was getting on the car a bit. After one short quick acceleration my CEL came on, the car drove fine and I said I would get it scanned the next day but the light went away. However, after it came on the car did not idle normal. It would sometimes dip to 500 and then back to 700, especially if the AC is on....whats up? Do I need to raise the idle? If so where is the idle control/valve?(new to K series)
Old Jun 23, 2009 | 12:00 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Idle problem
Obv something happened that caused the CEL to come on and the idle to change.
Dont mess the the idle settings since it was prob fine prior to your issue..
As far as the CEL, even if its not on, if you run a diag, you should still be able to see recent codes that were tripped I believe (depending on the diag tool maybe?)
Any other issues after the cel came on? It could be a wide range of things, you have to be more specific...
Old Jun 25, 2009 | 03:54 PM
Baron55's Avatar
CEL gone and everything is back to normal....
Old Jun 28, 2009 | 02:53 AM
bsivoljr's Avatar
Do you know what it was? A/C is supposed to cause a dip in the RPM slightly. About a couple hundred rpms usually.
Old Jun 30, 2009 | 08:41 PM
Baron55's Avatar
well the idle was bouncing around and going below 500rpm causing the car to vibrate as if it was stalling....anyways everything is perfectly fine now and I was not able to get what the code was, well not with the scanner i used atleast
Old Jul 4, 2009 | 02:03 PM
bsivoljr's Avatar
Probably was fuel related, like a slight clog
Old Jul 5, 2009 | 01:14 PM
Baron55's Avatar
yes you are right sir....CEL came back today code: P0172 system running rich....wtf!? o2 sensors????
ok so...about 6 hours later the CEL is gone and the car is back to normal....wtf???
Old Jul 6, 2009 | 03:53 PM
SlammedDC2teg's Avatar
It could be the o2 sensor, could also be the map sensor.
Old Jul 6, 2009 | 07:39 PM
Baron55's Avatar
how do I tell?
Old Jul 8, 2009 | 12:22 PM
Originally Posted by Baron55
how do I tell?
Test the o2 sensor buy hooking up a volt meter, if the voltage flucuates it's good and if it doesn't it's bad.
pfsmith99
Oct 14, 2012 09:02 AM
dllnzek
Aug 15, 2012 10:42 PM
JDMFreakz
12
Jul 11, 2012 10:54 AM
92bseries
Dec 7, 2011 12:59 PM
DK4200
Jan 23, 2004 11:27 AM
