oil pressure gauge
Old Jan 23, 2005 | 04:50 PM
steve00si's Avatar
Default oil pressure gauge
i searched and could not find any relevant info. i got an autometer oil pressure gauge for cheap and i'm loking to hook it up but i am a little weary about t-ing off the block because i've heard that it will break off and cause damage. what are other options for this install? any help will be greatly appreciated
thanks
Old Jan 23, 2005 | 04:51 PM
PHOBIA's Avatar
you can get reloaction kits that mount to the firewall.
Old Jan 23, 2005 | 04:52 PM
hondaeg8's Avatar
Default Re: oil pressure gauge (steve00si)
there is no other option. it will not break off. i've had mine on for a long time with no problems. i even have a cheap $6 one from wal mart.
Old Jan 23, 2005 | 04:56 PM
steve00si's Avatar
Default Re: oil pressure gauge (hondaeg8)
what about this thing? don't think i want to spend $30 though
http://cgi.ebay.com/ebaymotors...46100
Old Jan 23, 2005 | 04:59 PM
Kamin's Avatar
dude
read the damn auction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">this adapter goes between the oil filter and the engine block will work with only TOYOTA. NISSAN. LUXUS.</TD></TR></TABLE>
revvin9k's Avatar
Uncorrect my friend, I am proof that it does break off, it happened to me and it was hooked up correctly. And it is a major pain in the *** to remove depending on where it breaks.
I have the relocation kit that allows you to use both the autometer gauge as well as the factory one.
I'll try and dig up a pic.
Old Jan 23, 2005 | 05:02 PM
steve00si's Avatar
Default Re: oil pressure gauge (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">dude
yeah i saw it but there is one for hondas
thanks for the help.
here you go happy now?
http://cgi.ebay.com/ebaymotors...&rd=1
Old Jan 23, 2005 | 05:03 PM
revvin9k's Avatar
Default Re: (PHOBIA)
It's located on the firewall and you can see the two plugs running to it,just behid th IM.
Old Jan 23, 2005 | 05:09 PM
steve00si's Avatar
Default Re: (S(J)O(D)L(M))
hey thanks for the help do you remember where you got it from and how much?
Old Jan 23, 2005 | 05:14 PM
revvin9k's Avatar
Default Re: (steve00si)
I got it from the shop I use i'll IM you tommorrow. I think it was $15 to $25.
Old Jan 23, 2005 | 05:17 PM
ralphie14's Avatar
Edelbrock makes a sandwhich adapter also that goes between your filter and your block there are pre made holes that are the right size for the fitting that comes with your guage also. I bought one for the guage and also to have an oil feed for my turbo. It is safer than going off the back of your block and does not require you to relocate your filter.
I can take pics if you want but I got it from Speedway motors here in Lincoln
Old Jan 23, 2005 | 05:19 PM
revvin9k's Avatar
Default Re: (ralphie14)
I did'nt have to relocate my filter..........look at the pic. Does the Edelbrock allow you to still use your stock oil pressure gauge. Just in case the Autometer gauge went out and did'nt work at least you have reassurance that the stock one is still there.
Old Jan 23, 2005 | 05:22 PM
ralphie14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) &raquo;</TD></TR><TR><TD CLASS="quote">I did'nt have to relocate my filter..........look at the pic. Does the Edelbrock allow you to still use your stock oil pressure gauge. Just in case the Autometer gauge went out and did'nt work at least you have reassurance that the stock one is still there. </TD></TR></TABLE>
I will go take a pic for you just a minute.
Old Jan 23, 2005 | 05:27 PM
Grip's Avatar
im gonna do my oil pressure guage this spring..im using a flexable stainless steel line that screws into the back of the block where the oem plug was then at the other end of the line i have a t fitting with the sender in one end and the oem plug in the other..im gonna make a bracket to mount it down low on the firewall so nobody can see it
Old Jan 23, 2005 | 05:38 PM
ralphie14's Avatar
Default Re: (Grip)
Here is the one that I have.
ZXRider
Sep 11, 2006 11:49 PM
klppride
Jun 14, 2005 06:33 AM
n0pinitr0us
21
Apr 10, 2005 08:55 PM
2khb
Mar 10, 2005 06:52 PM
crx1856
Aug 8, 2003 02:11 PM
