swap
Old Jan 23, 2005 | 04:29 PM
eh2..765's Avatar
Default swap
i have an 88 crx si i am wanting to do a dohc zc swap i was wondering if someone could tell me everything i need to do the swap thanks
Old Jan 23, 2005 | 04:31 PM
crexer's Avatar
Default Re: swap (88crxjdm88)
no one has ever done that swap. Dont even bother searching
Old Jan 23, 2005 | 04:33 PM
PHOBIA's Avatar
try here,from what i understand its a pretty good resource https://honda-tech.com/zerosearch
Old Jan 23, 2005 | 04:36 PM
untitled's Avatar
Default Re: (PHOBIA)
yea, that **** is a crazy swap, i bet you couldnt even find anyone on this site whos ever actually completed the swap even if you did <FONT COLOR="red"><FONT SIZE="6">SEARCH</FONT></FONT> the archives.
Old Jan 23, 2005 | 04:37 PM
efcivic757's Avatar
You will need a complete zc longblock, everything else is a straight bolt in. another good place to look in http://www.thezcr.com lots of good zc info
Old Jan 23, 2005 | 05:45 PM
31flavorscivic's Avatar
Default Re: swap (efcivic757)
yea all you need is the longblock. I was unfortunate and had an SI with a cx engine/tranny, so I had to buy the engine + tranny, and then I also had to buy the int.shaft and axles to complement that. I would recommend going with the ZC ecu also because of the higher rev limiter.
But, SI tranny has better gearing for the engine than the zc tranny from what I hear. That is a combo a few of my friends went with, and they like it.
Old Jan 23, 2005 | 07:12 PM
cbp_crx's Avatar
Default Re: swap (31flavorscivic)
yeah id just get the motor and the ecu, it will bolt in with no mods needing to be done, from what i hear, the zc ecu has 112 mph speed limiter, if that doesnt bother you, get that one, it would work the best
Old Jan 24, 2005 | 09:33 AM
eh2..765's Avatar
Default Re: swap (crx_si6)
so i dont need any mounts or shift linkage for a dohc zc to fit in my car?
Old Jan 24, 2005 | 09:49 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxjdm88 &raquo;</TD></TR><TR><TD CLASS="quote">so i dont need any mounts or shift linkage for a dohc zc to fit in my car?
No the ZC bolts right in like you were replacing your stock engine with another one.
Old Jan 24, 2005 | 04:22 PM
eh2..765's Avatar
Default Re: swap (91civic)
also my single cam tranny fits up tO A DOHC?
Old Jan 24, 2005 | 05:16 PM
CRX_Control's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxjdm88 &raquo;</TD></TR><TR><TD CLASS="quote">also my single cam tranny fits up tO A DOHC?</TD></TR></TABLE>yes
Old Jan 24, 2005 | 05:29 PM
The DX Rex's Avatar
Default Re: swap (CRX_Control)
go ZC
Old Jan 24, 2005 | 06:19 PM
PHOBIA's Avatar
it all works and fits because they are both d seires blocks.every thing is re usable. however upgrading some componets has an advantage like a si ecu and tranny.
Old Jan 25, 2005 | 03:41 PM
eh2..765's Avatar
thanks for all the help
kyle1jzsupra
Aug 20, 2008 10:19 AM
the niz jiz
11
Sep 30, 2004 05:50 PM
my_slow_civic
Sep 29, 2002 09:06 PM
KiddieRydesCRX
May 20, 2002 01:58 PM
Rob!
Mar 12, 2002 02:54 PM
