hi... my car died
Old Jan 23, 2005 | 12:40 PM
doug piston's Avatar
Default hi... my car died
i have a 92 cx with a b16a. today while at a stop light my car just died and will not restart. fuel pump does make noise so i think it works. no spark comin from out of the plug i pulled. when i turn the key to the second position i do here a relay click so i dont think its the traditional honda main relay problem. car turns over at normal speed so i dont think it is the timing belt either. i think its the coil or iginitor. any other ideas would help me on my quest so if you have any pls let me know.. thanks
Old Jan 23, 2005 | 12:41 PM
Combustion Contraption's Avatar
coil & ignitor problems are notorious on honda's.
Old Jan 23, 2005 | 12:42 PM
thats what i thought. could it be anything else?
Old Jan 23, 2005 | 12:45 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (doug piston)
have you checked your ecu? nothing foul smelling or burns noticeable...?
Old Jan 23, 2005 | 12:47 PM
smell fuel but i think thats due to no spark. is there a way to to check the ecu beside pluggin in another one?
Old Jan 23, 2005 | 12:49 PM
thanks for the ideas by the way. i sure this has been asked about 8905511515456 times. just thought i might be missing something
Old Jan 23, 2005 | 03:44 PM
can ignitors and coils fail while the engine is running???
Old Jan 23, 2005 | 04:41 PM
cockrummotorsport's Avatar
Default Re: hi... my car died (doug piston)
Checked you alternator.
Old Jan 23, 2005 | 05:17 PM
civiccpedx's Avatar
Default Re: hi... my car died (cockrumracing)
yes the igniter and coil can fail while the car is running. it happened to the guy that owned my car. Easy, but costly fix. I bought a brand new dizzy from distributorking.com and it started right up. but if you are getting no spark but power to the dizzy then that is your problem. The dealer says that happens in the 92-95 year hondas often.
Old Jan 23, 2005 | 05:58 PM
ITLNstallion818's Avatar
Default Re: hi... my car died (civiccpedx)
what about fuel filter? my car was doing that awhile back...
its like 20 bucks, easy install....
Old Jan 23, 2005 | 09:32 PM
already replaced fuel filter about 10000 miles ago
Old Jan 23, 2005 | 09:38 PM
shorty0o29's Avatar
Yeah my ICM went out one day while i was just crusing to work on the highway at 70. new ICM costs at least 150 dollars... if thats the problem i would look into a used one on here
Old Jan 23, 2005 | 10:00 PM
Spoolin93si's Avatar
Default Re: (shorty0o29)
Same thing happend to me the other day and it was my coil. I replaced it and the car fired right up.-
Old Jan 23, 2005 | 10:04 PM
Eyes Only's Avatar
try to make sure your plugs are good eliminate some problems that you know might have been it
Old Jan 24, 2005 | 11:48 AM
it was the ignitor. in the process i also changed the cap, rotor and plug wires. everything all good now. thanks for all the suggestions
vdrive502
Apr 6, 2018 02:37 PM
mobenavides
Jun 17, 2008 05:14 PM
spooncivic01
Feb 17, 2008 11:29 AM
XstouterX
Mar 5, 2006 02:28 PM
Sephro
Oct 1, 2002 04:30 AM
