Running N20
Old Jan 22, 2005 | 11:25 PM
2kstreetcivic's Avatar
Default Running N20
alright, I have a d16y8 and I have been thinking about running a dry shot of n20 for some extra kick.....I was thinking about getting a kit like the ZEX kit that is a 55 dry shot...my question is i have simple bolts ons I/H/E hi flow cat, but nothing else done to the engine..is running N20 gonna damage my engine?..and what are the risks of something in the n20 setup going wrong..thanks
Old Jan 23, 2005 | 06:22 AM
JdmEKCivic's Avatar
Default Re: Running N20 (2kstreetcivic)
just make sure you dont run more than a 75 shot with your setup
Old Jan 23, 2005 | 07:21 AM
red91sit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kstreetcivic &raquo;</TD></TR><TR><TD CLASS="quote">alright, I have a d16y8 and I have been thinking about running a dry shot of n20 for some extra kick.....I was thinking about getting a kit like the ZEX kit that is a 55 dry shot...my question is i have simple bolts ons I/H/E hi flow cat, but nothing else done to the engine..is running N20 gonna damage my engine?..and what are the risks of something in the n20 setup going wrong..thanks</TD></TR></TABLE>
Zex is probobly the safest n20 setup out there, It's got quite a few safety check points before it finally injects the laughign gas. You might want to consider some colder plugs if you inject a larger shot, or retarding the timing a few degrees. Generally you don't have to worry about these thogh unless your running 75 or up.
Old Jan 23, 2005 | 10:24 AM
Default Re: Running N20 (red91sit)
sp basically if I run a 55 shot, and dont use it every time a hit the gas, then my engine will be fine??...
Old Jan 23, 2005 | 03:55 PM
red91sit's Avatar
Well you can never guarantee these things, but yeah you should be fine. Of course dont' use it in 1st and 5th or at too high of speeds.
si0385.
40
May 12, 2006 05:21 AM
loooong69
May 27, 2004 06:46 PM
acuraqc
Feb 5, 2004 04:33 PM
MonsterVtec
Aug 17, 2003 03:01 PM
Sohc Driver
Dec 13, 2002 08:42 PM
