how har is to install 4-2-1 header anyone got pics
Its not complicated but not easy either. Its pretty straight foreward as far as what to do. Loosening the bolts can be a chore though. Do yourself a favor and get some liquid wrench or something ahead of time. Good luck.
Pretty easy. Its just bolts. Though some of those bolts can be hard to remove. All you need are some simple sockets/wrenches and a jack/stands. PB blaster will make things a bit easier.
http://www.c-speedracing.com/h...r.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phenom3030 »</TD></TR><TR><TD CLASS="quote">On the DC 4-2-1 two piece header, does anyone know what size the bolts are that connect the upper piece to the lower piece?</TD></TR></TABLE>
14mm
but the whole job only requires 10mm 12mm 14mm maybe 17mm
14mm
be warned, noob question
What does a 4-2-1 header actually do, what kind of header is stock and what is the benefit of a 4-2-1 over whatever is stock. All i know is that they connect sum part of the engine to the exhaust...
:What does a 4-2-1 header actually do, what kind of header is stock and what is the benefit of a 4-2-1 over whatever is stock. All i know is that they connect sum part of the engine to the exhaust...
