stock 88 pgm-fi 1.5.. idle loping
Old Jan 22, 2005 | 07:55 PM
PePiTo88lx's Avatar
Default stock 88 pgm-fi 1.5.. idle loping
Went through and checked timing at TDC on #1 and distibutor and crankshaft pulley, all lined up good. so timing is on... but idle cycles from 3 down to 2 grand when heating up to op temp, then tries to drop to norm idle but keeps the loping from about 1500-2000, starts pattern as soon as fire up and will nt stop. don't want to touch ECU less i have to cause im kinda noob on that, looked through some strands but couldnt find one for my eng app. Whats next? EACV? O2 sensor? HELP?
Old Jan 22, 2005 | 08:14 PM
93formula's Avatar
Default Re: stock 88 pgm-fi 1.5.. idle loping (PePiTo88lx)
mine does that too, except when cold it idles real low and when its warm it hunts from time to time, it could be a vacuum leak.
Old Jan 22, 2005 | 08:16 PM
thumbtack's Avatar
check your Fast Idle Thermal Valve (FITV) mine caused the bad idle... search for FITV there is a lot of threads about how to correct this issue.
Old Jan 23, 2005 | 12:50 AM
AllmotaB18EH2's Avatar
Default Re: stock 88 pgm-fi 1.5.. idle loping (thumbtack)
i just fixed mine, my tps sensor was messed up, maybe you could try somone elses throttle body to see if your idle is fixes, good luck
Old Jan 23, 2005 | 12:40 PM
hatchi's Avatar
any check engine light?? adj. your tps and check iac
ex94vtec
14
May 6, 2006 02:07 AM
ITSTOCK
Oct 28, 2004 12:03 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
SpoolnG2
Jan 8, 2003 09:13 AM
Spade
Jul 1, 2002 10:49 AM
