ABS code is right front, please help with next question
I did a reset and code popped up right away....what should i do check next before i go buy a new sensor and have it installed....
1. Is there anythng i should clean?
2. Should i adjust the sensor so its closer(possible?) ?
3. anything else????
Please help me out guys!!!!!!!!!!
Im not sure but if you need any ABS parts i took out my whole system yesterday and have all the sensors, harnesses, lines, modulator, everything. If you need something let me know.
1. No, there's nothing you can clean that will help this problem.
2. Anything's possible, but this is not something that you would want to try & it wouldn't help anyway.
3. You'll want to check your front ABS relay, that's the only other thing that would cause this code. If the relay is good, it's time for a new sensor.
ptsiu
Oct 22, 2003 03:52 AM
