ABS code is right front, please help with next question
Old Jan 12, 2002 | 05:52 PM
JimmieD's Avatar
Default ABS code is right front, please help with next question
I did a reset and code popped up right away....what should i do check next before i go buy a new sensor and have it installed....
1. Is there anythng i should clean?
2. Should i adjust the sensor so its closer(possible?) ?
3. anything else????
Please help me out guys!!!!!!!!!!
Old Jan 13, 2002 | 04:23 AM
boosted3g's Avatar
Default Re: ABS code is right front, please help with next question (lsinteg)
Im not sure but if you need any ABS parts i took out my whole system yesterday and have all the sensors, harnesses, lines, modulator, everything. If you need something let me know.
Old Jan 13, 2002 | 06:38 AM
joemama's Avatar
New User
i had the same code before, and before i got around to checking the sensor the abs light went away on its own
Old Jan 13, 2002 | 07:12 AM
94gsr's Avatar
Default Check your relay
1. No, there's nothing you can clean that will help this problem.
2. Anything's possible, but this is not something that you would want to try & it wouldn't help anyway.
3. You'll want to check your front ABS relay, that's the only other thing that would cause this code. If the relay is good, it's time for a new sensor.
tobytigger
Jun 23, 2015 04:31 PM
derickshonda
Sep 26, 2013 03:36 PM
94BlueGSR
Oct 21, 2006 12:06 PM
ptsiu
Oct 22, 2003 03:52 AM
