replacing z6 valves
Old Jan 22, 2005 | 12:18 PM
TuningOptions's Avatar
Default replacing z6 valves
just wondering on how necessary it is to have headwork done on an almost stock rebuild - upgrading the cam and springs and new factory valves - will I be alright with just swapping out the valves or do i have to have work done on it first?
Old Jan 22, 2005 | 12:24 PM
jlacoy82's Avatar
71.192.16.183
Default Re: replacing z6 valves (TuningOptions)
Slow down. Breath.
What are you asking? Are you just doing an all OEM rebuild? Are you slapping a larger cam in? Are you doing cam and valve springs?
If you arent doing anything too radical, the OEM valves are fine, just use new ones.
And no, you dont need any work done to require replacing valves, it certainly cant hurt to have fresh parts in there.
Old Jan 22, 2005 | 12:25 PM
slambedcivic's Avatar
if youre doing a STOCK rebuild, why not use STOCK parts?
Old Jan 22, 2005 | 12:28 PM
Default Re: replacing z6 valves (jlacoy82)
Slightly larger cam with heavy duty springs.
Factory valves.
My question was if I needed to have any machine work done when putting in new valves.
Old Jan 22, 2005 | 12:29 PM
just get your valve seats re-ground to ensure a good seal
Default Re: replacing z6 valves (slambedcivic)
Because I want to rev a little higher.
Old Jan 22, 2005 | 12:30 PM
Any way to do this myself?
Old Jan 22, 2005 | 12:32 PM
jlacoy82's Avatar
71.192.16.183
Ummmmmm, get valve springs to match the recommended pressures of the camshaft manufacturer, dont just get the heaviest spring possible thinking its "better".
And just get the valves re-seated and should be good to go.
Old Jan 22, 2005 | 12:36 PM
Right I understand that about the springs, any idea of cost on getting the seats reground? Done it yourself?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TuningOptions &raquo;</TD></TR><TR><TD CLASS="quote">Any way to do this myself?</TD></TR></TABLE>
yes, but if you are unsure, have a machine shop do it. doin it is cheap, having the tools to do it, isnt
Old Jan 22, 2005 | 12:37 PM
cool - thanks
Old Jan 22, 2005 | 12:48 PM
not a problem
Ferarrikiller
Jul 7, 2008 09:33 PM
p0gi_b0i_integra
Nov 27, 2007 06:49 AM
fms1day
13
Jul 12, 2006 05:29 AM
Agip
Jan 18, 2005 08:18 PM
LsBack
Sep 19, 2004 01:04 PM
