is this how your suppose to do it?
bleeding radiator-
filled the radiator fluid to the top with the cap off, turned on my car squeezed the top radiator hose and saw all the air bubbles escape did this for 5 mins until the car reached normal operating temp. i had to add fluid once or twice but when i was done i had to barely add any at all, but i re-opened the cap and addded so more again, is that ok or do i have to re-do it now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicBlueTeg »</TD></TR><TR><TD CLASS="quote">also make sure to set the inside ac/heater(blue red) control all the way to the hot setting... but dont turn on the fans(0 1 2 3 4)</TD></TR></TABLE>
damnit i had the fans all the way at 4, should i bleed it agian?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fafsa »</TD></TR><TR><TD CLASS="quote">
damnit i had the fans all the way at 4, should i bleed it agian? </TD></TR></TABLE>
do i have to redo it since the fans didnt turn on? how do u know if the thermostat opens/turns on?
if the thermostat didnt open the car wouldnt operate at normal temp. but a sure fire way to test it is to pull it out and put it in hot watter and see if it opens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon »</TD></TR><TR><TD CLASS="quote">if the thermostat didnt open the car wouldnt operate at normal temp. but a sure fire way to test it is to pull it out and put it in hot watter and see if it opens</TD></TR></TABLE>
well it runs fine at normal temps, so i think it should be ok
Christopherian1982
17
May 17, 2008 12:04 PM
