is this how your suppose to do it?
Old Jan 22, 2005 | 10:58 AM
fafsa's Avatar
Default is this how your suppose to do it?
bleeding radiator-
filled the radiator fluid to the top with the cap off, turned on my car squeezed the top radiator hose and saw all the air bubbles escape did this for 5 mins until the car reached normal operating temp. i had to add fluid once or twice but when i was done i had to barely add any at all, but i re-opened the cap and addded so more again, is that ok or do i have to re-do it now?
Old Jan 22, 2005 | 11:25 AM
DarkDragon's Avatar
Default Re: is this how your suppose to do it? (fafsa)
iv always heard u need to add fluid while its runnig not while its off
Old Jan 22, 2005 | 12:30 PM
doubledown's Avatar
That's pretty much it. Just make sure the car warmed up enough for the thermostat to open, squeeze the top hose to get rid of the air and call it a day.
Old Jan 22, 2005 | 01:21 PM
DAguyLS's Avatar
thats the ghetto fab way. They put a bleeder on there for a reason. But the aforementioned works ok too.
Old Jan 22, 2005 | 01:37 PM
SonicBlueTeg's Avatar
also make sure to set the inside ac/heater(blue red) control all the way to the hot setting... but dont turn on the fans(0 1 2 3 4)
Old Jan 22, 2005 | 02:31 PM
fafsa's Avatar
Default Re: is this how your suppose to do it? (SonicBlueTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicBlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">also make sure to set the inside ac/heater(blue red) control all the way to the hot setting... but dont turn on the fans(0 1 2 3 4)</TD></TR></TABLE>
damnit i had the fans all the way at 4, should i bleed it agian?
Old Jan 22, 2005 | 03:02 PM
fafsa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fafsa &raquo;</TD></TR><TR><TD CLASS="quote">
damnit i had the fans all the way at 4, should i bleed it agian? </TD></TR></TABLE>
do i have to redo it since the fans didnt turn on? how do u know if the thermostat opens/turns on?
Old Jan 22, 2005 | 06:45 PM
DarkDragon's Avatar
if the thermostat didnt open the car wouldnt operate at normal temp. but a sure fire way to test it is to pull it out and put it in hot watter and see if it opens
Old Jan 23, 2005 | 10:20 AM
fafsa's Avatar
Default Re: is this how your suppose to do it? (DarkDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote">if the thermostat didnt open the car wouldnt operate at normal temp. but a sure fire way to test it is to pull it out and put it in hot watter and see if it opens</TD></TR></TABLE>
well it runs fine at normal temps, so i think it should be ok
Christopherian1982
17
May 17, 2008 12:04 PM
luvs2spooge
Feb 19, 2007 10:45 PM
DFW
10
Jan 22, 2005 05:04 PM
DFW
Jan 22, 2005 04:00 PM
Understeer
Oct 8, 2004 05:27 AM
