Radiator........which of these?
Old Jan 22, 2005 | 07:53 AM
tthomass's Avatar
Default Radiator........which of these?
Did some searching and was wondering which to get. I've got a 99SI who's engine is basically stock but may do some minor things in the future. Had a accident and the radiator etc is shot. I plan to start autocrossing in the spring and was wondering:
#1 should I upgrade or just get a OEM replacement and from where?
#2 i've seen that Koyo, Fluidyne are popular but whats this also about using a Del Sol dual core......assume its a oem Del Sol radiator?
#3 i need to have the ac so if any void having ac then i don't want it
So basically, what radiator should I get for my 99SI with its basically stock engine with little upgrade in its future? -Doubt I boost even thought I'd like a Vortech SC but maybe cams etc are in its future
Old Jan 22, 2005 | 08:09 AM
tthomass's Avatar
Default Re: Radiator........which of these? (tthomass)
and for a radiator support, this place on ebay has the assembly for a 99coupe for just under $90.........thats about as cheap as i'll find it or is there somewhere else recommended? http://cgi.ebay.com/ebaymotors...33645
thanks for the help!! now who wants to put an SI back together????
Old Jan 22, 2005 | 08:19 AM
ProjectLSVTEG's Avatar
For the body parts I would recommend http://www.partschannel.com they had my core support for like 48 bucks on my eg. and they have fenders, hoods, bumpers for cheap too.
Old Jan 22, 2005 | 08:33 AM
00Red_SiR's Avatar
All Motor Mentor
Keep your stock SI radiator, they've been proven to cool your car adequately for many people that are running boost etc. It just doesn't have the same bling factor as an aluminum one but that would just be overkill IMO.
Old Jan 22, 2005 | 09:04 AM
Benbuilt4u's Avatar
Default Re: Radiator........which of these? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Keep your stock SI radiator, they've been proven to cool your car adequately for many people that are running boost etc. It just doesn't have the same bling factor as an aluminum one but that would just be overkill IMO.</TD></TR></TABLE>
what he said stock is good enough
Old Jan 22, 2005 | 09:10 AM
tthomass's Avatar
Default Re: Radiator........which of these? (Benbuilt4u)
ok well i'll start looking around on the internet for one...........any particular places ya'll reccommend? thanks for hte help
Old Jan 22, 2005 | 09:17 AM
tthomass's Avatar
and i'm still checking out the del sol since its dual core thicker etc................i am assuming that while i'm at it i should go a head and maybe just get the del sol since its a little better????? and prob about the same price too
so del sol or si radiator? and what year del sol radiator?
Old Jan 22, 2005 | 01:24 PM
00Red_SiR's Avatar
All Motor Mentor
I believe the Si radiator is a dual core stock like the del sol radiator. Someone correct me if I'm wrong. My car is in storage so I can't easily go check.
Old Jan 22, 2005 | 02:09 PM
egizzle8
Guest
Posts: n/a
How bout a streetimport radiator? only 150 for a full AL radiator? Otherwise dual cores are super cheap now on ebay.
Old Jan 22, 2005 | 02:30 PM
tthomass's Avatar
Default Re: Radiator........which of these? (egizzle6)
pm'd
Old Jan 22, 2005 | 03:40 PM
EG1.8cT68's Avatar
Any automatic civic radiator will work (92-00) they are all dualcore, but for the money Streetimports is the way to go, ugly welds but they work.
Old Jan 22, 2005 | 06:23 PM
tthomass's Avatar
Default Re: (EG1.8cT68)
yeah $150 + the shipping...........i think it was $189 shipped, have to see what just a oem from Advance or Autozone or online instead.........if considerably less, why waste the money for nothing better
Old Jan 22, 2005 | 06:58 PM
tthomass's Avatar
Default Re: (tthomass)
here's an example, what do you think? http://cgi.ebay.com/ebaymotors...33602
Old Jan 22, 2005 | 07:23 PM
litterbox's Avatar
I am a (Trial User) Army
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthomass &raquo;</TD></TR><TR><TD CLASS="quote">here's an example, what do you think? http://cgi.ebay.com/ebaymotors...33602</TD></TR></TABLE>
This one looks like it's primarily designed for a D series but will fit your B series with an adapter plate. You'll need to find out how much that plate will cost you. Great price though.
Old Jan 22, 2005 | 07:55 PM
tthomass's Avatar
Default Re: Radiator........which of these? (litterbox)
but since its also del sol i figured its the same dual core people swap out for the dame fit..........the early model civic's though made me wonder
Old Jan 22, 2005 | 08:18 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">
This one looks like it's primarily designed for a D series but will fit your B series with an adapter plate. You'll need to find out how much that plate will cost you. Great price though.</TD></TR></TABLE>
WTF are you smoking. First of all a dual core is out of a B series del sol, second of all it doesn't matter (no "adapter plate" needed), third of all that price is a little fishy.
Old Jan 22, 2005 | 08:55 PM
litterbox's Avatar
Default Re: Radiator........which of these? (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">
WTF are you smoking. First of all a dual core is out of a B series del sol, second of all it doesn't matter (no "adapter plate" needed), third of all that price is a little fishy.</TD></TR></TABLE>
I don't think you understood my post.
1)When did I ever say that a dual core wasn't out of a B series.
2)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBAY Seller &raquo;</TD></TR><TR><TD CLASS="quote">
Upgrade your SOHC engine (EX, LX, DX models) radiators to this high quality dual core radiator!! *Si model owners will only need to get an adaptor to fit the inlet and outlet of the radiator which you can find them in any auto parts store.
</TD></TR></TABLE> That's straight from the Ebay description. This is a dual core radiator that'll fit all 92-00 civics (B and D). B series requires an adapter plate.
3)Yes, I agree with you, the price is fishy as hell.
Anyway, we're arguing over stupid ****.
Old Jan 22, 2005 | 08:58 PM
spankey167's Avatar
From what i know 92-95 Del Sol Vtecs and Si's came with half size dual core radiators. Mines a 92 si and it has one
Old Jan 23, 2005 | 05:06 AM
tthomass's Avatar
Default Re: Radiator........which of these? (spankey167)
yeah screw the ebay one............can someone just give me a comparison between the stock OEM 99-00 SI radiator to the aluminum StreetImports radiator?
EX: quality of the StreetImports rad, how well it works, cool any better than the stock oem........just don't want to get a POS
I just need to order one and get my can back together (see avatar) THANKS
Old Jan 23, 2005 | 10:38 AM
hb_guy's Avatar
here is the streetimports one on ebay dammit!!
http://cgi.ebay.com/ebaymotors...&rd=1
$149 + ship
a phuckin steal
and if you are worried about the b series and cooling don't worry. i've had 2 turbo setups in my eg hatch both d and b series and the STOCK one works just
Old Jan 23, 2005 | 11:11 AM
DFW's Avatar
DFW
Default Re: Radiator........which of these? (hb_guy)
#1 OEM replacement
#2 Koyo</TD></TR></TABLE>
Either one of those will be fine.
Old Jan 23, 2005 | 11:20 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: Radiator........which of these? (DFW)
That streetimports radiator looks like ****. For me, something in charge of an important part of my car will not look like it's about to explode.
I've had a couple Modine dual-cores in my car and they've worked great on/off the track w/ a B-series.
Old Jan 23, 2005 | 04:17 PM
ABK's Avatar
ABK
Default Re: Radiator........which of these? (SkyeC)
okay what's the point of spending $150 for some fucken radiator
when you can just go out to your local parts store and buy a dual core for like $100. And no you don't need no fucken adapter plate.
blknpurple
22
Feb 12, 2012 04:33 AM
SlowPokeEg
Apr 27, 2006 10:49 PM
Go-Cart
21
Feb 26, 2004 08:31 AM
Geeboy
Feb 6, 2002 06:13 PM
