damnit!@!!$!(%
installed my new radiator today, after driving around for about 5mins i noticed smoked coming from under the hood... both hoses were on tight so is it the radiator that was messed up? at first it didnt drip but a drop and after 5 mins of driving, in which i hit full boost once or twice and the rest was just regular driving. the temp needle only reached the half way point before i got my car home and turned it off.
i didnt bleed all the air out of the cooling system, does that seem like the result, of what i mentioned above? could i have f*cked anything up?
i thought i blew a head gasket or something but the overfill bottle is the same and theres no oil in it or anything, so if i just bleed the air out will it be ok? or what can i check for to see if anything is messed up
it just keeps purging out from somewhere i cant see, not at first, but when the car warms out it starts coming out like purge and drips
when u install a new radiator, ur suppose to keep the cap off, turn on the car and pour radiator fluid in it. this will make sure u dont have air bubbles in the system which can cause heatspots on the cylinder walls and thats bad.
