steering has a lil play after extended stud install
Old Jan 22, 2005 | 03:21 AM
BoOsTiN Dc2's Avatar
Default steering has a lil play after extended stud install
Like the topic says, after i installed my extended wheel stud my steering wheel has a little bit of play. When im stopped i can move the steering wheel 1 inch to the right or left without any strenght, and when i WOT it kinda shifts either left or right a little since the steering wheel feels kinda loose. This is after i installed my extended wheel studs. I tooked off the brake caliper, the rotor, and the castle nuts on the lower control arm and the upper control arm. I did not mess with the tie rod. Do anyone know what would have caused this? It feels kinda scary when im on WOT because it kinda shift left and right due to the loose steering wheel feeling.
Old Jan 22, 2005 | 05:57 AM
Dan GSR's Avatar
Default Re: steering has a lil play after extended stud install (tRaCeBuStAbUsTeR)
did you press off the hub to change the studs?
lildragon'07
13
Jun 2, 2010 08:31 AM
vti444
Jun 16, 2007 02:36 PM
BoOsTiN Dc2
Suspension & Brakes
Jan 23, 2005 03:26 PM
alias 33
10
Jan 25, 2004 05:30 PM
