Knocking wheels
Hi folks
I have a 96 accord 2.0litr ils with 85000 on the clock, recently, when right turning the car has begun to make a knocking sound, which seems to come from the left front wheel. Can anyone tell me what they think this problem is and how to rectify it.
I'm pretty useful when it comes to cars but have never had this happen before, I'v checked around the wheel but cant see a problem apart from split gator can someone help out please?
Hazzo
Modified by Hazzo at 5:26 AM 1/22/2005
Hazzo
you mean you have a 2.2 not 2.0. Its probably your axle. When your cv boot rips it tosses all of grease all around the inside of your wheels causing the cv joint dry out and click. i may be wrong, it could be somethin else
CD7
No, not a 2.2, I'm in UK, its a 2.0 ils, but I think your and the others answer to the problem is right, would replacing the boot/gator sort the problem, I dont think its been this way for long. Hazzo
if that is the case replace the cv boot as soon as possible so you won't have to replace the entire axle, I had the same problem and had the change axle and the boot. if the problem is bad enough the bearings may need to be replaced in addition to the previously stated parts.
how long has it been clicking??
car is going nowhere till fixed now, boot is torn but no play at wheel, just the noise while turning right, will be repairing this week.
Thanks for the rapid responces. Hazzo
I'v tried to find a replacement axle over here and have been quoted $600 just for the part, a local independant who does work that I cant get at, such as this, has looked and is going to replace the dodgy cv joint and both boots for 300.
I think this is a deal over here as the parts will be around the 180 mark.
What do you folks here think. Hazzo
teamhonda_johnb
Honda Civic (2001 - 2005)
Feb 18, 2009 10:13 AM
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
