spoon sports transmission drain plug measure?
Old Jan 21, 2005 | 07:47 PM
cxSHOE's Avatar
Default spoon sports transmission drain plug measure?
got the answer thanks
Modified by cxSHOE at 5:52 PM 1/22/2005
Old Jan 21, 2005 | 11:55 PM
BEEZERone's Avatar
Default Re: spoon sports transmission drain plug measure? (cxSHOE)
ok just measured it its 1.2 centimeters
Old Jan 22, 2005 | 07:42 AM
cxSHOE's Avatar
Default Re: spoon sports transmission drain plug measure? (BEEZERone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEEZERone &raquo;</TD></TR><TR><TD CLASS="quote">ok just measured it its 1.2 centimeters </TD></TR></TABLE>
ok check again and see if that comes to 12mm (i want to make sure) and i appreciate your time. thanks
Old Jan 22, 2005 | 08:14 AM
Orangecivic251's Avatar
i have one out in my tranny so i couldn't tell ya but hey love them both why do ask the measurement?
Old Jan 22, 2005 | 08:20 AM
cxSHOE's Avatar
Default Re: spoon sports transmission drain plug measure? (OrangeCiviC251)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 &raquo;</TD></TR><TR><TD CLASS="quote">i have one out in my tranny so i couldn't tell ya but hey love them both why do ask the measurement?</TD></TR></TABLE>
im going to have a magnet made for me and i need measurements. i know i can just buy a spoon set and be done. but i can have a custom one made with a stronger magnet put on for about $15 bucks. just experimenting thats all.
Old Jan 22, 2005 | 08:28 AM
00Red_SiR's Avatar
All Motor Mentor
There's 2.5 cm in an inch and 25mm = an inch, so that would be right about 12mm.
Old Jan 22, 2005 | 08:33 AM
cxSHOE's Avatar
Default Re: spoon sports transmission drain plug measure? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">There's 2.5 cm in an inch and 25mm = an inch, so that would be right about 12mm.</TD></TR></TABLE>
i know the conversion is correct. i want to make sure his 1.2cm is correct... im not sure if he measured by mm then converted to cm to make it easier for me or if he only had a cm ruler and came up with that measurement.
in other words 12mm is exactly 1.2 cm so maybe he measured in mm and then converted it to cm ... ill have to see what he says.
Old Jan 22, 2005 | 10:28 AM
hayabusa160's Avatar
just woundering i just got the spoon drain plugs theres one with a really long magnet that one is for the oil pan right.
and the short one is for the tranny
Old Jan 22, 2005 | 10:30 AM
cxSHOE's Avatar
Default Re: spoon sports transmission drain plug measure? (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">just woundering i just got the spoon drain plugs theres one with a really long magnet that one is for the oil pan right.
and the short one is for the tranny</TD></TR></TABLE>
correct.. measure the transmission one so i can confirm its 12mm from base to the top of magnet
Old Jan 22, 2005 | 10:34 AM
i see thanks
its 21mm from base to top of magnet
magnet is 6mm long
Old Jan 22, 2005 | 10:37 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">i see thanks
magnet is 6mm long</TD></TR></TABLE>
and let me know if you can measure the transmission one so i can lock this thread look at photo above to see what i need measured
Old Jan 22, 2005 | 10:42 AM
hows that
Modified by hayabusa160 at 2:52 PM 1/22/2005
Old Jan 22, 2005 | 11:15 AM
cxSHOE's Avatar
ahh never mind i saw your post above at 21mm great thanks for your help.. i appreciate your time
Old Jan 22, 2005 | 11:28 AM
np
Old Mar 3, 2005 | 11:30 AM
ibme_uk's Avatar
hayabusa160,
I've pm'd you incase you don't see this post.
Need to know how magnetic your bolts are compare to the one's I've brought.
BlueR
Oct 10, 2007 06:40 PM
saer
Jun 8, 2005 08:56 AM
civicsir.com
11
Feb 7, 2004 10:09 AM
Trellis
May 22, 2003 12:44 PM
