Amp question involving bridging.
I'm getting a new amp since I finally got my perfect 12.
The stats on the amp are:
» 60 watts RMS x 4 at 4 ohms
» 90 watts RMS x 4 at 2 ohms
» 180 watts RMS x 2 bridged output at 4 ohms
I have a question though, it can also be mono, so will it still be 180 watts or do you think It can put out 360 watts rms?
This is the amp in question.
http://www.crutchfield.com/S-f...C8401
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">no your going to get 180w and thats it.</TD></TR></TABLE>
Hmm okay, I hope thats enough in that case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow »</TD></TR><TR><TD CLASS="quote">
Hmm okay, I hope thats enough in that case.</TD></TR></TABLE>
Actually.......... Is that speaker a dual 4 ohm voice coil if this is the case the yess you would get the extra power.l
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow »</TD></TR><TR><TD CLASS="quote">I'm getting a new amp since I finally got my perfect 12.
</TD></TR></TABLE> I don't know of any 4ch amp that can be monoed
but as nsxxtreme said.....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">
Actually.......... Is that speaker a dual 4 ohm voice coil if this is the case the yess you would get the extra power.l</TD></TR></TABLE> you could bridge the amp into a 2ch and wire one channel into each VC, although I don't recomend it, I would use 2ch to run the front speakers on highpass and bridge the other 2ch for the sub
94
but as nsxxtreme said.....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">Actually.......... Is that speaker a dual 4 ohm voice coil if this is the case the yess you would get the extra power.l</TD></TR></TABLE> you could bridge the amp into a 2ch and wire one channel into each VC, although I don't recomend it, I would use 2ch to run the front speakers on highpass and bridge the other 2ch for the sub
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> I don't know of any 4ch amp that can be monoed
but as nsxxtreme said..... you could bridge the amp into a 2ch and wire one channel into each VC, although I don't recomend it, I would use 2ch to run the front speakers on highpass and bridge the other 2ch for the sub
94</TD></TR></TABLE>
so if its a dual 4 VC how do you suggest wiring it then? 2 ohm or 8 ohm??
the amp isnt 2ohm stable and is gonna put out dick all for power at 8ohms so why do you not recommend it?
94</TD></TR></TABLE>so if its a dual 4 VC how do you suggest wiring it then? 2 ohm or 8 ohm??
