just put on rear disk brakes
Old Jan 21, 2005 | 04:26 PM
ThisLittleSleepeR's Avatar
Default just put on rear disk brakes
i just put on rear disk brakes on my dx, everything went well besides cutting myself on the heat shield trying to take off the e-brake lines. my question is are there any other methods in putting on the e brake lines, im saving it for tomorrow. the bolts to the lines are in the weirdest places and hard to get to.
Old Jan 21, 2005 | 04:30 PM
ISSUES-EG's Avatar
Default Re: just put on rear disk brakes (ThisLittleSleepeR)
what year is ur car?
Old Jan 21, 2005 | 04:31 PM
Default Re: just put on rear disk brakes (issues_ek)
92
Old Jan 21, 2005 | 04:49 PM
2lua's Avatar
do it right the first time so you don't have to redo it again. remove the exhaust, the heat shield, then bolt on the parking brake cables.
Old Jan 21, 2005 | 05:10 PM
Icyrain's Avatar
Did it the other day and didn't have to remove the exhaust. But it was a 98. Here is how I did it. Loosened the heat shield. When you're in the car tie some strings to the ends of the cables and put some petroleum on them (the cables). Pull them out past the rubber fittings. Get new cables tie the string to them. Put some duct tape on them so they don't snag as much going in. You might want to do the tape thing when pulling them out too but I didn't. Put some petroleum on the tape and then pull the string from inside the car and they'll come in. Remove tape and connect ebrake cable to bracket.
Old Jan 21, 2005 | 05:38 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: just put on rear disk brakes (Icyrain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icyrain &raquo;</TD></TR><TR><TD CLASS="quote">Did it the other day and didn't have to remove the exhaust. But it was a 98. Here is how I did it. Loosened the heat shield. When you're in the car tie some strings to the ends of the cables and put some petroleum on them (the cables). Pull them out past the rubber fittings. Get new cables tie the string to them. Put some duct tape on them so they don't snag as much going in. You might want to do the tape thing when pulling them out too but I didn't. Put some petroleum on the tape and then pull the string from inside the car and they'll come in. Remove tape and connect ebrake cable to bracket.</TD></TR></TABLE>
That sounds like way more work to me. Here is what I did (94cx)...
Un bolted the exhaust pipe at the muffler (2 bolts)
Remove Exhaust pipe from rubber hanger nearest muffler
Un bolt heat sheild (4 bolts)
Remove heat sheild (pull exhaust pipe left or right to remove
Now you have access to your cables (no tape or lube)
Installation is the reversal of removal
One of the Integra E-brake brackets doesn't line up on the drivers side, so be prepared to get creative.
Old Jan 22, 2005 | 08:02 AM
Default Re: just put on rear disk brakes (94eg!)
thanks
Old Jan 22, 2005 | 08:25 AM
Archidictus's Avatar
Unceasing Measure
While you're ******* with heat shields, you might as well just leave them off so they never rattle
Old Jan 25, 2005 | 09:20 PM
Default Re: just put on rear disk brakes (Archidictus)
speaking of that, it is rattleing, pain in the ***. i was just under there bending the metal n stuff, didnt quite get it, gotta go back under tomorrow.
Old Jan 25, 2005 | 09:40 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">While you're ******* with heat shields, you might as well just leave them off so they never rattle </TD></TR></TABLE>
That's what I did and I don't regret it at all. It was in the way of trying to push those rubber things in and I was like, "**** it, let's pull it out."
The_RedBaron
May 26, 2014 01:10 PM
Hanmin
Sep 30, 2010 10:32 AM
joelmatt89
11
Mar 9, 2009 05:30 PM
globy123
Aug 15, 2007 05:27 PM
dropped like its hott
Feb 7, 2007 09:30 PM
