had ecu chipped now fuel pump wont turn on
Old Jan 21, 2005 | 01:31 PM
93_db2's Avatar
Default had ecu chipped now fuel pump wont turn on
i had my ecu chipped through silverbeast here on ht. i know he has a bad rap now.
but i was wondering if any one knew what would cause the fuel pump to stop turning on after being chipped. it worked fine before i sent it to him. does any one know if it could be repaired?
the ecu is a obd1 pr3.
Old Jan 21, 2005 | 07:43 PM
93_db2's Avatar
Default Re: had ecu chipped now fuel pump wont turn on (dohciv420)
Old Jan 22, 2005 | 09:15 AM
743power's Avatar
i've had that happen with a bad chip before. Check the back of the board to make sure none of the solder is shorting out the circuits.
Old Jan 22, 2005 | 10:00 AM
Irish Integra's Avatar
This may be a longshot but check your fuel pump relay...they tend to give trouble on older Hondas. It's usually located near the fuse panel inside the car.
Old Jan 24, 2005 | 01:12 PM
93_db2's Avatar
Default Re: had ecu chipped now fuel pump wont turn on (Irish Integra)
back of the board is clean, and ive tried it in 3 or 4 cars. same result
Old Jan 24, 2005 | 01:32 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohciv420 &raquo;</TD></TR><TR><TD CLASS="quote">back of the board is clean, and ive tried it in 3 or 4 cars. same result</TD></TR></TABLE>
cut J1 and try it.
Old Jan 24, 2005 | 06:34 PM
kidrolla's Avatar
Default Re: had ecu chipped now fuel pump wont turn on (743power)
i have a 90crx and sometimes i have to turn my car on and off about 20 to 30 times before the fule pump will kick in. do know where i can find a pic of it so i know what im looking for.
Old Jan 27, 2005 | 04:02 PM
Default Re: had ecu chipped now fuel pump wont turn on (kidrolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidrolla &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90crx and sometimes i have to turn my car on and off about 20 to 30 times before the fule pump will kick in. do know where i can find a pic of it so i know what im looking for.</TD></TR></TABLE>
Definately the fuel pump relay, under the dash near the fuse panel.
Old Feb 23, 2005 | 04:50 PM
JRciv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohciv420 &raquo;</TD></TR><TR><TD CLASS="quote">but i was wondering if any one knew what would cause the fuel pump to stop turning on after being chipped. it worked fine before i sent it to him. does any one know if it could be repaired?
the ecu is a obd1 pr3.</TD></TR></TABLE>
Hey, I've got a chipped p28 with the same damn problem. Did you ever figure out the problem?
jdmAccord210
Engine Management and Tuning
Oct 22, 2013 11:22 AM
type Gendy
Jul 3, 2013 06:30 PM
boostedjd
Jul 3, 2013 06:05 PM
Galan
May 21, 2011 03:55 AM
no_rice_please
Oct 12, 2009 09:36 PM
