what head gasket to use on a d16y8 head on a d15 bottom end???
Old Jan 21, 2005 | 12:36 PM
crxhf_gsr_blades's Avatar
Default what head gasket to use on a d16y8 head on a d15 bottom end???
what head gasket to use on a d16y8 head on a d15 bottom end??? also what timing belt to use? do they make a ecu that would kick v-tec for an obd0? thanks for your help
Old Jan 21, 2005 | 12:53 PM
Pantysniffer's Avatar
Default Re: what head gasket to use on a d16y8 head on a d15 bottom end??? (crxhf_gsr_blades)
use a y8 headgasket and y8 timing belt(not sure) you can run a standalone shift light or rpm activated switch off your existing ecu to run vtec though.
Old Jan 21, 2005 | 02:04 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf_gsr_blades &raquo;</TD></TR><TR><TD CLASS="quote">what head gasket to use on a d16y8 head on a d15 bottom end??? also what timing belt to use? do they make a ecu that would kick v-tec for an obd0? thanks for your help</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=635580
Old Jan 23, 2005 | 11:19 AM
thanks, the information is very helpful
efjones9
Dec 27, 2010 06:54 AM
vtec8200
May 4, 2010 04:13 AM
lilsicsoul
Mar 11, 2009 04:21 PM
BoostNEF
Jul 10, 2005 11:52 PM
bmrgold
May 12, 2003 06:14 AM
