help with O2 sensor
i cant find the plug to plug in my o2 sensor to my engine, been searching everywhere..does anyone know where it is located?>, i have a b16 sirII in an eg ...if someone can find a pic of where it is that would be helpful, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrazyMC »</TD></TR><TR><TD CLASS="quote">i cant find the plug to plug in my o2 sensor to my engine, been searching everywhere..does anyone know where it is located?>, i have a b16 sirII in an eg ...if someone can find a pic of where it is that would be helpful, thanks</TD></TR></TABLE>
more importantly: which engine harness are you using? if your're using a b-series or d16z6 harness, the 4-pin connector should be close to the knock sensor/oil pressure sensor wires.
if you're using the stock d-series (non vtec), the plug will be closer to the tranny reverse switch plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
The d16z6 has the o2 at the front of the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrazyMC »</TD></TR><TR><TD CLASS="quote">theres no sensors in the front, theres just one on the end of the headers</TD></TR></TABLE>
Then that's where your plug should be.
BlueShadow
Jan 16, 2005 11:04 AM
